Hey all,
Got the below items for sale as they are no use to me anymore..
Item: Nismo 600cc top fed injectors
Age: not sure, injectors were flow tested and cleaned before purchase
Condition: good, flow tested and cleaned before purchase
Price: $550.00 delivered
To Fit: (What car) top fed RB26
Contact: PM me
Comments: Will up some pics up tomorrow. they are the purple ones
The 600cc injectors wont cut it for my application so they have to go..
Item: RWD RB26 sump, has diff cut off and drive shaft welded up also have a #8 oil return feed. (tomie baffle not included)
Age: New (was only dummy fitted)
Condition: as above
Price: $550.00
To Fit: (What car) Suit RWD RB26 project
Contact: PM me
Comments: Had this sump modified by Jays Racing, its a standard alloy rb26 sump with the diff cut out and drive shaft welded up. It top quality work and took over 8 hours to create. I will post pics up soon and you will see the quality work! Its all Alloy construction and looks better then a factory sump!
Item: JUN Oil Pan Baffle Plate for RB26dett
Age: Brand new
Condition: Brand new
Price: $450.00 FIRM delivered anywhere is Oz.
To Fit: (What car) RB26dett
Contact: PM me
Comments: Helps with oil control to the oil pickup
This is the best aftermarket baffle on the market, its brand new in the box bought for $540. Part number 1028M-N001
Item: GTR resistor pack
Age: Brand new
Price: $140.00 delivered FIRM
To Fit: (What car) anything running low imp. injectors
Contact: PM me or reply here
Comments: bought two by mistake, also have OEM RB26 injectors and rail..
Item: Genuine R33 Gtr rear wing, painted mid night purple (was on a 40th ann. shell I purchased recently)
Age: used
Condition: used
Price: $450.00 ono
To Fit: (What car) R33 gtst
Comments: Bought a do luck rear wing so not needed.
Item: RB26 stock pistons and rods (05U)
Age: used
Condition: used out of a 80,000km engine
Price: $300.00 ?
To Fit: (What car) Rb26 or make a RB24
Comments: Dont need it, going forged
Item: A31 (Cefiro) engine cross member
Age: used
Condition: straight no rust
Price: $200.00
To Fit: (What car) anything you want
Comments: Dont need it, was going to do a 26/30 but decided against it. so this is no longer needed.
Hey all,
Contact: PM me
Condition: as above
Price: $550.00
Contact: PM me
Age: Brand new
Contact: PM me
Age: Brand new
Age: used
Condition: used
Price: $450.00 ono
Age: used
Price: $300.00 ?
Age: used
Price: $200.00
  • 3 weeks later...
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
