How ya doing guys, new to the site and hello to all,
Sins u guys down under have been playing around with Skyline alot longer than anyone here in ireland i taut it would be a good place to start asking ur views on what i should do next...
Engine as it stands it spec'ed as follows:
HKS filter
Apexi Plugs
R33 GTR FMIC
Japspeed turbo elbow and down pipe
Full hi-flow exhaust
Uprated fuel pump (have srad reg not fitted unsure of what pressure to set it to)
and mapped with HKS F-CON S
This is the power i ran (it was shout out mode so hopefulling u guys can compare)
I wanna run more power (as everyone dose) but im not sure what ta do next..
I was searching on here a good bit of info:
Was looking at Plazmaman Inlet but in my heart i know its only gona be for looks and im sure i could spend my money in other places n get more gains
cams n adj cam gear? (HKS or Tomei) looking at tomei pon cams lift isnt as much as HKS ones? (or GTR?)
Trubo wise... im totaly in the dark, RB25? hear there lagy on a RB20 but how lagy are they? and other good after market turbos out there???????????
Iv got a bit of cash to spend but id like the cash to power ratio to be good...
Any views or ideas ?
(just noted that i scaned the wrong dyno sheet meet to do the one with fueling mapped too its running a small bit rich up hi around about 10.8:1 at max power)
https://www.sau.com.au/forums/topic/224763-rb20-dyno-results-whats-next/
Have a look through the RB20 dyno results thread.
Cheapest way to get another 50rwhp is an RB25 turbo. Don't know if you have a tuner who can remap your ecu over there but that would help get rid of some of the lag.
My RB20 made 245rwhp untuned at 12psi through an RB25 turbo, was a LOT better than the stock turbo even with the extra lag.
Aftermarket wise I'd probably be looking at something along the lines of a HKS 2530 but you'll need to sus out who can tune your car, be it remapped stock ecu (which is what I have done) or full aftermarket.
Hey mate, as bubba advised I'd be looking through the RB20 dyno results thread up top of the forced induction modification section.
For a comparison i had my car on the dyno over 3 months ago with everything stock (motor, turbo, injectors etc) bar the following modifications:
- Hybrid type 600x300x76 FMIC
- gktech dump + front pipe 3"
- high flowed std cat :(
- 3.5" cat-back
- Apexi Power Intake
- Bosch 040 fuel pump
Without the boost touched i managed 159.0rwkw or 213.22whp running real rich AFR's and pretty flat through the mid-range.
My car will be placed again on the dyno tomorrow morning after having my std ECU remapped to suit these mods that touched up some ignition timing, lean up the fuel mixtures and got rid of a few restrictions. I'll update you soon.
If you want more power an easy upgrade would be to an RB25 turbo and add a little more boost. If looking for a lot more power for a lot more money go a 2530, bugger injectors and probably Z32 AFM with a new tune to suit.
Well i can get the Fcon mapped over here in ireland all bits have been done by myself mapped by a HKS dealer here in ireland....
Anyone know what RPM u get full boost using a Rb25 trubo? think im getting full boost at about 2750RPM with my current set up..... boost came up on its own using the Fcon as it cuts all limits think its around .8 bar
Hope to get HKS navigator also which will help with setting up....
As for cams?
yea agree with the other post, mine pumps out 300rwhp i have a to4e turbo externaly gated plazmaman intake plenum 550cc injectors aftermarket fmic pod filter 300lph fuel pump 3.5" cat back exhaust hi flo cat oh and after market exhaust manifold and a ems stinger 4 ecu piggy backed to a mines chipped ecu
So a GT2530 is a good ballence between response and power 200 - 220kw.
But to really bring the RB20 to life you should get a td06 kit 260kw ish. A bit laggy but really packs a nice punch.
In both cases you will need injectors.
RB25 turbos are only slightly better that RB20 turbos. You still have the same problem of ceramic turbo wheels which dont last long on high boost.
So what about a GT2535? or GT2540?
been loking at turbos on yahoo auctions need to find someone to get it tho....
Also plazmaman inlets? worth the money or better off spending the money on a set of HKS cams?????????
Bubba: what kinda lag are we talking about when using RB25 turbo??????????
So what ya's think? turbo or cams next? or any other ideas?
What is the budget? Personally i dont think the RB25 upgrade is all that brilliant, it needs a re-tune, and a few tweaks and the cheapest it will ever be is around a $1000 upgrade. But if thats the budget thats all you can really do.
If you have the budhet for more then 180rwkws then you are going to have to consider fuel pump (if you dont already haev one) and AFM (or an eco that doesnt require AFMs, injectors and a change to cooler and exhaust pipework.
The step to a turbo , even like the 2530 is considerably more money.
a set of 444cc GTR injectors or 555cc Nismo/other injectors and then add your turbo of choice.. 2530/2535/2540 are all good choices depending on what you want (response vs power)... will need aftermarket AFM too at this point... Z32 is ~$300
if you really have cash, i'd consider not spending any more money on this engine, and doing an rb25 / rb26 transplant.. The RB20 doesnt scale up as well as the other 2 engines, and the extra half a litre displacement is nice.
how ya doing thanks for the help lads............
Iv got about 2000dollars to play with....
3300RPM dont seam to bad for the RB25 trubo..... but if i can find a broker in japan for yahoo auctions im sure i could pick up a GT2530/35/40 for cheap.....
I want good usable power..... dont wanna be on n off boost when gunning it.... find my turbo runs out of go at about 6000rpm good any where from 3000 to 6000 tho....
Edited by GTSr32(IRISH)
hey,
im irish and new here too. i have a plazmaman plenum and i highly recommend it...
believe me its not just for looks. the increase in torque is serious and the sound is awesome. im doing a td06 rebuild at the moment...
nice td05 on yahoo at the moment man
Hey mate i have a friend who put a r33 turbo on his rb20. Deffinately wouldnt call it laggy. They gotta be the best value for money upgrade for a rb20 it you have a tight budget. Or you could always spend a little bit more and get a 34 turbo for that little bit of extra power.
