Hey guys got my r32 skyline over 6 months now and just realised it has a rb20det ecu in it (engine is a rb25det btw). How can this be? I thoght 25 ecu's have different pin outs than rb20 ecu's. Also VCT isnt supposed to work with the rb20 ecu is it? And i think my VCT is working fine... could be wrong though, any way of checking? Anyway just wanna know if anyone can help me work out whether my loom has been modified or something as the ecu hasnt been. Also rb25 power fc works in the car so im just really confused. Any help would be great...
Thanks guys
https://www.sau.com.au/forums/topic/224814-rb20-ecu-in-my-rb25/
The computer will plug in to both looms. RB20 Cpu can be remapped / rechipped to suit RB25 and auctually when you want a remapped cpu for a rb25 workshops always use the the rb20 cpu. The reason is the rb20 cpu has a removable chip and is easy to remap / rechip. The rb25 cpu does not have a removable chip and cant easily be upgraded (Upgrade chip to suit Rb25 motor for an Rb20 computer is about $40 + $70 for TV repair type person to install)
Most likely you will have a rb25 engine, rb25 loom and rb20 computer chipped to run a rb25. and of course a rb25 powerfc will fit and not sure what the guy who poste above means but the power fc completely replaces the std computer
Edited by Brokenz
brokenz: thanks that makes sense, so does that mean that the ecu cant work in a rb20 anymore? and could it work in other rb25 engines?
nismoh: no problems mate, all running great. Although i didnt do the engine conversion, bought the car with it already done. Definatley recomend the upgrade though mate
hey im in the middle of doing the rb20 ecu with a rb25 tune chip on a rb25 but ive connected the computer and the car runs fine but no tacho just wondering if you need to change the tacho wiring on the ecu from pin 7 to pin 5 to suit the rb20 ecu
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
