Hi All,
I bought my R32 a couple of months back and I've just fitted up some new wheels. I'm keen to get the ride height down by 10-20mm, and I understand that I might be able to do that with the suspension that's already in there.
I bought it with Bilstein shock absorbers fitted but still with standard springs, I think. I was going to get new springs but I've been reading about the adjustable circlip on the Bilstein shocks. Do all Bilstein shocks have this adjustable feature?
Basically I'm hoping that someone can give me a really basic and step by step guide on what I need to do to move the circlip down a notch or two. Do I need to take the wheel off and pull the suspension apart to be able to get to the adjustable part, or can it be done much easier than that? I'm not even sure which bit I'm looking for. I know this will be an obvious question to some, but I've searched and can't find the answer here or on Google.
Would really appreciate some tips.
Thanks.
no, not all bilstein's are adjustable. if u have circlip adjustment, its pretty simple for the 32, u have to take the wheel off, take the shock absorber and spring out (2 nuts on the strut tower, 1 on the bottom attaching it to the "hub"), compress the spring if the spring is captured (with spring compressors), lift the seat up, take the circlip out of the groove and put it on a lower groove, then drop the seat back down onto the circlip, uncompress the spring and put the shock and spring back in, do the nuts back up and put the wheel back on.
Thanks, that's helpful. Is it obvious when looking under the car whether the shocks are adjustable before I go and buy a spring compressor and take it all apart? What am I looking for? Just the grooves around the shock? Make sure it's not already adjusted all the way down?
If you can see the bottom spring seat then it should be pretty apparent whether you have extra grooves or not.
You will be able to see them straight away.
Like nisskid said, they're not all adjustable. The adjustable ones you have probably seen around the forums had the circlip grooves machined into the shock body by the person that sold them.
Is it possible to compress the spring and remove+reinstall circlip without pulling the whole shocker out?
it is, but i wouldnt recommend it, it will take longer than just undoing a few bolts. its very hard to get the spring compressors on the spring in the car, and even if u can somehow get it on, it will most likely be very uneven and the spring will compress uneven, im not sure if its enough force to damage the damper, but its not a risk id take. as i said, 2-3 bolts on the strut tower (depending on the car) and 1 at the bottom, takes like a minute to do, and make the rest of the process a lot easier and quicker.
Alright, I need some more help with this.
I went to give it a go today without taking the shocks out (limited time frame) but there's no way to compress the spring enough to get the seat at the base of the spring to move. So you're right about that. I'm willing to have a go at getting the shocks out, but I need some more info on the process. I'm told that to get the rear shocks out you need to get the back seat forward and remove the parcel shelf or something? This is info coming from Unique AutoSports in Seven Hills. They offered to do it but said it'd be 3-3.5 hours in labour. Can anyone shed some light?
Even better, if anyone in Sydney has done this and can help me with it tomorrow morning, that'd be fantastic. Please PM me. Otherwise, some info or pics on the process of removing both front and rear shocks would really really help.
hey mate, ur rear strut towers in the 32 are in the boot. 3-3.5hr labour is quite simply ridiculous, it takes me roughly 20 mins to do without a proper hoist etc.
open ur boot, undo the 2 nuts (13mm if i remember right), undo the nut at the bottom (17 or 19mm), and take it off, seriously its not worth trying to do with it on the car.
Damn. So I spent nearly 10 hours on the car trying to get this job done today. What a massive pain in the arse. You were right about the rear shocks - very easy to remove. Well, at least one side was. The driver's side is proving to be a real pain, with the base of the shock being secured so tightly, I'm going to need to get a pro to loosen it with a rattle gun. The other side was a piece of cake - strut out, circlip moved, strut back in and fasten in about 20 mins. The fronts however, were an entirely different story.
To get the thing adjusted I had to remove the struts and take the whole spring off the shock and then hit the seat of the spring with a hammer to get it off the circlip before it could be moved. Then compressing the spring to get it back on the shock is a real damn hard job when the compressors are too short to reach over the whole thing, and they suck balls anyway and just bend. I ended up using giant clamps to get it done. It took hours and hours to do both fronts, as I've never done it before and didn't really know what I was doing.
I do have one question: at the top of the struts in the front, there was what looked like a red gasket between the underside of the mounting to the car body itself, and the top of the strut when it bolts in. The gasket had become really brittle and cracked, so I pulled it off on both sides and just put the suspension back in. Do I need to replace that gasket? Thanks.
haha well at least u know what ur doing now, i guarantee u the knowledge u will have gained from doing it all will be very valuable down the track. with the tight nut, what are u using? try getting some leverage on it, a pole or something on the end of a socket wrench will do the job. also what spring have u got in there? sounds like they are stockies, they are an absolute prick to compress as they are so long and are fairly well preloaded in there.
i know the gasket ur talking about, im not sure how vital it is, i certainly dont use it anymore as it looked pretty screwed and insignificant, but u might want to get confirmation on that.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
