Hey Guys,
I've got a S2 R33, a consult cable, and the nisdatascan software. What i want to know is if it is possible to determine when a knock occurrs... the ecu error code can tell you that a knock DID occur, but how useful is that? Wouldn't it be better to know at what RPM the engine knocks? Is this possible to do in our cars, i mean, without the stethoscope and a keen set of ears?
Cheers
https://www.sau.com.au/forums/topic/224823-knock-sensor-logging/
Hey Guys,
Cheers
the ECU error code for knock sensor doesnt tell you if a knock occurred. it tells you if it detects a fault with the knock sensor.
I have datascan and as far as i know it cannot log the knock sensor. As Pete said above, ECU error code for detonation sensor circuit just means that your det sensor circuit is showing an abnormal resistance (open circuit, dead sensor etc) and will trigger the error code.
When your car does detonate it will go into safety mode, it will not show an error code.
Have you considered an aftermarket product like a knock-link? You can read up about them on the AMEC website ( www.amecautocare.com.au ) under the electornics section.
I don't know if this applies to all Nissan's, but I do know that on the Zed the knock sensor is only monitored by the ECU up until approx 3500rpm... after that the sensor can get confused between normal engine vibration/noise and detonation and may put you into safety maps even though you're not detonating. I reckon the best way would be something like a knock-link.
theoretically if you know what memory address in the ecu that the ecu uses for whether its in safe mode or not, then you can monitor that, but im not sure its generic (location could be different for diff cars) and it will just be a yes/no, not an amount.
a knock lite or similar would probably be the best choice.
your other alternative is to get something like a Knock Link LED det display unit, which BTW we can get for you :ermm: I have one in the race car, the LEDs usually start flickering at the top of the rev range.
oh another product that is similar is the TurboXS knock lite.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
