i used to be quite an active member here when i had my last r32, but i have been lurking in the shadows for the last few years
but im happy to say im back with avengance on the skyline scene with the purchase of a black r32 v spec gtr :D
i have a bit of work to do to it but once its sorted ill be back in with the crew and catching up with some old mates again (most of which i have kept in touch with) and keen to make new ones
for those who dont know me the names Jon and im from toowoomba and im a plastic welder :) and i like women... ALOT!! :banana:
Edited by WHITE R32
https://www.sau.com.au/forums/topic/224841-im-back/
  • Replies 40
i am on there a fair bit for the classifieds section as foamer_69, as there usually are a fair few items for sale in the bris area.
got no negative feedback for you, was just wondering as you ocassionally had some r32 parts for sale and was just checking whether it was the same person.
https://www.sau.com.au/forums/topic/224841-im-back/#findComment-3960367
heya Will whats happenin mate....still got the black GTST? youre the one who should have an r34!!! still got the cappa??
eugene you should come to the skidpan day slip and i are having james is comming too :blush: good to catch up with everyone again
hahaha actually saw Will yesterday too... he's gone euro.
keen to head to the skidpan, trying to get my car running first!
https://www.sau.com.au/forums/topic/224841-im-back/#findComment-3962345
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
