Stock R32 Gtr Steering Wheel, Fibreglass N1 Vents
Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
Liking the new charger, battery all good (I think). Also like how you can put it in power supply mode too. Will troubleshoot with that sometime soon. -
I have the 7170 there, sorry if I'm a little paranoid but I'm not into clicking ambiguous links - can you share an image of it?
