hi people
i own a skyline r32 i got a canery satnight for tyres airfilter n reverse lights
anyway i fixed all that no problem i came to my roadworthy tester and he found a few faults he told me i couldnt have my guages next to the stereo bcz it might break some'1s knee in an accident i agreed on that even though i didnt think they were to bad and i didnt get my roadworthy coz of that
a pic of how the guages were is attached so if ur intrested take a look
anyway that isnt my main point i took them off all was fine now he has found one more thing
when i have my normal lights on and i turn my high beems on my normal lights turn of so its only the high beems i thought that was normal for skyline but he says both the standard and highbeems have to be on at the same time when high beems are switched on if any1 can help me with that please do...
he claims its an electrical fualt but its been like that for 2 years since ive had the car and i highly doubt his right.
thanx...
https://www.sau.com.au/forums/topic/22486-lights/
thanx guys really appreciate it yes, i thought they worked like that i mean im no mechanic by far but i now a bit bout skylines, yeah and i did take the guages off can u believe he actually told me to put them on the dash were it wouldnt get in the way im like, ummmmmmm and the police he didnt comment ow well thanx again
https://www.sau.com.au/forums/topic/22486-lights/#findComment-482350
ditto to cobo_11
my headlights stay on when the high-beams are on
maybe its like the tail lights where some people only have the outer 2 come on when they turn the headlights on, yet all 4 come on when they brake. yet, all 4 of mine come on when i turn the headlights on... hmmmm
https://www.sau.com.au/forums/topic/22486-lights/#findComment-489406
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
