S13 turbo
good diff
stiff suspension
drivers seat, steering wheel, gear stick, dash, good front tyres.
Basically, after that it's practice and money.
Can't remember who it is that is up there in the AUS drift scene who has an S13 or is it a onevia (s13 and 180 front end) who has about 220rwkw and is one of the most competitive cars on the scene..
a stock S15 turbo'd SR20 with tuning and fuel mods etc will make about 200rwkw.
a stock S13 is about 1100kg.
remove anything not required and close to 1000kg.
  • Replies 71
S13 turbo
good diff
stiff suspension
i think it was leighton fines old peer onevia
Get a commodore
any model will do... vs, vy, vt
find a corner...
go around it fast and stab throttle...
this is cheap and will have you drifting in no time.....
or the other suggestions sound ok i guess
Aren't most commodores single spinners?
So you get this drift and sometimes it will almost seem to snap back on you when the other wheel decides to spin instead?
Stick with the Silvia's, the NissanSilvia forum's are into drift ...
Get a commodore
find a corner...
yeah right....all that will do will cause the car to fishtail, hit the gutter and flip onto its roof or wrap around a telegraph pole....Or if its a single spinner...lay one big black line down...I wouldnt try to drift a commodore unless I had some major suspension work..Stock they are awful
now heres THE cheapest way to drift.. Take any front wheel drive car, place 2 McDonalds food trays under the rear wheels and pull the handbrake on...Then take off !!! - Hint the trays usually last longer if its wet weather
i say with starting off.. build yourself a pretty decent r31 manual rb30.. I currently have one now, just standard with a tune to run slightly better (advance timing, richened up) without a locker in the wet i get it on pretty stupid angles.. Way more fun to throw around than my 300kw r33 that i purposly built for drift.. (Because it doesnt pick up speed to over 130km/h in 3rd gear when sideways :P )
So get yourself a R31
r32 rear coilovers
s13 front coilovers
swaybars
strut bars
strip the shit out of the interior
adjustable front arms and rods
s13 brakes
Alloy rad
4.11 diff gears
minispool with 28 spline axles
exedy heavy duty clutch
bodge your own exhaust
get it running nice.. always service it..
If you want extra beef.. add a high lift n/a cam
and you have yourself a drift car :D and trust me.. u can throw them around something kronik
Edited by LTHLRB
You must be doing it wrong then....
Make sure you have ACDC cranking, your wearing correct attire (wife beater, footy shorts and thongs) and your hand out the window holding a stubby cooler with a can of VB in it...
THEN youll be able to drift a commodore
Stick your mates in the back, some cases of beer in the boot and youll be the next DRIFT KING
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
