  • Replies 71
are there better options outside of nissan?
well the coronas are pretty tuff...
theres an 'avante' model with a 2.4 liter 4cyl. can get them under 2k
the toyota tarago (smooth shape) has the 100kw version of the engine, can do head swaps etc and get a pretty decent setup as they have a fair bit of torque...
but its hard to go past an R31.....
in some drift series thing that was in tassie 2 of the podium placers were R31s
look for 'jpriseman' as he was one of the place takers....
Another car is a cressida.... they are a bit more exxy but really strong if you put a thicker headgasket in etc...
i reckon just go for the R31,
even a R31 pintara with a CA18det if you like revs!
Yeah 31, c'mon surely you've heard of Fatz, Easo, and the stuff that the Drift Battle Lads got up to with the wags a while ago :thumbsup:
Youtube 'DriftMajik', for a long time there he was just running a locked diff, stock RB30e and some stiff springs... really cutting sick and ripping it up the bigger toys.
rb30 with a mild cam and a turbo.. extra injectors.. good tune.. 4.11's.. good clutch.. locker.. strip the f**k out of it.. cage it.. alloy rad.. good cooler.. oil cooler.. and your off.. prob all up under 8k including car
too much f*cking around to go with those injectors, RB30 use hosetail type injectors, so you'll need a custom/aftermarket rail, then you gotta make sure you got the right impedence (dunno what skylines use) and then remap. just buy bigger straight fit ones and remap IMO. stock VLT injectors will top out just shy of 200rwkw (although a few have gone over 200) and that should be enough for 'cheap' drifting
Yeah, wanna stick with n/a and cheap so i can't really see myself hittin 200rwkw. Was just hoping that they used similar enough injectors... Don't really know too much bout rb30's :P
hmm where to start....a gtst or its cousins the cefiro or laurel is preffered, how ever it can be done with a R32 gts4 and gtr's by pulling the 4wd fuse and installing a switch for when you decide to play in the sandpit."thats what i did"
jenny craig, the maximum you should have in the car is a seat,seat belt, three pedals, a handbrake and half a dashboard...along with the sterring wheel and column
then its the forum,s no use buy bling bling rims as they wont take long to get so dirty and scratched
you'd think you bought them from the scrap yard anyway, 16 or 17 inch should do for starters.
even sets of two's as you'll note when you watch the drifting the back and fronts are missmatched anyway.
followed by the shoe shop, ya dont need new ones, just good condition second hand ones and a few nearly bald ones for practicing on,
then next its off to the cogswapper shop for an overhaul you can drift an auto"i do due to a knee injury" how ever a manual is preffered, stock boxes dont last long being quick shifted as it is hard on the sincro's i had a box last only the first corner 1st 2nd then nothing stripped third.
then its time to stiffin the b*tch up, get here resting nice n snug on the road, you dont need anything flash to start with, just some king springs and a GOOD set of shocks for those ripple strips the ass end is going to be driving most of the day and followed by good bushes, whitle line nolethene etc etc,
if you feel the car's factory lsd is worn to the point it wont work effectivley anymore now is the time to get a new one as it will be needed anyway, usually overhauled every 8 to 12 months or between seasons.
good front brakes, when using the feint method of drifting have the brake bias toward the front as when applying the brake is will shift the wieght forward onto the front wheels making it easier tobrake traction on the rear, leave the rears standard just good pads and fluid there as the hand brake will do most of the work on the back brakes
you'll need a good catch can with two inlets and a breather aswell as a drain back fitting to the sump as the track marshalls will probably require you to have one, must hold atleast a litre but most guys go for ones that can hold half the crank case volume.
that will get you started, you dont need massive horse power to drift, just need to learn how to use the vehical enursia to shift it side ways, feinting is the term used pull left then back right for example, when the weight of the vehical is back on the right side pull the hand brake to break the rear wheels from traction and dump the clutch stomping the accelerator and it will power steer out, correct the front wheel direction and let her slide,
the other way is to over power, this form requires torque from the engine come into the corner wide, change down dumping the clutch as above and the rear will slide out.
the other form is rather technical it requires no braking what so ever, go into the corner at speed letting the vehicals sideways enersia taking the rear out ,control the slide with the accelerator, the more gas you give it the further sideways the vehical will want to travel. as it does this the vehical will want to slow, this is how rally drivers take corners on gravel, so hp and torque are essential to overcome the high grip levels of tarseal.
then a hydralic hand brake as the stock one you got there wont last a day of continual stretching, ensure it has no ratchet just a pull lever.
good luck.
cef's and laurels are worth 12k stock over here.....
not exactly cheap
and in all honesty they need a cage or they flop around badly.
Otherwise, they are great cars. I'd love to get a laurel for a daily to be honest.
the minimum requirement for the stil vodka drift series as a entry level competiton, rollcage, fire extginguisher and a fia approved harness and helmet and fireproof suit, other wise you car could be stock standard for all they care aslong as the saftey requirments are met............as the D1NZ is too comercialised and you need a good 60 to 100 grand just to do one full year,
also the cars are road legal warrant and rego.
you'll need a rollcage anyway so it sort makes it irralavent weather your chassis got flex or not.
wow 12 g for a laurel. last one i picked up was rb20det manual with lsd for 4 g with fresh gloss black paint.
but thats what happens when your govenment lets the country get flooded with grey imports, the prices fall through the floor and you can see a potential drag,race,sprint,rally car parked on every studentflat's front lawn.
so much was the demand for go fast cars there are more grey import nissan skylines here then holden commodores
Bare minimum requrements;
RWD
Manual
Welded/Locked diff
Hardcore weight saving - I am assuming this wont be your daily so piss off EVERYTHING that weights more than 100grams and is not ESSENTIAL for the car to move (Air con, power steering, all interior, audio etc.)
Then;
HD Clutch
Front and rear strut and sway bars
Second hand coilovers
Decent tyres for the front
Still have money? Take care of the intake and exhaust of the car and something to bump up power (FMIC & Boost/Cams ecu tune)
Your looking at less than 3K for all of the above and you have yourself an awesome starting point to catapult yourself into the world of drifting.
What are your options?
R31
R32 (a little more expensive)
S12
S13
KE70
AE86 (a little more expensive)
Out side the typical "drift car" box you also have
MA70's
RX7 S1/2
And i have seen Ghetto Volvo's that go sideways very well!
Have a look around and see what your budget alows you to buy and what you want/like
ok... so i have now got my hands on:
RB20det
GTT turbo
GTST injectors
GTT fuel pump
SAFC 1
Rays Gram lights 57max 17X8 / 17x9 (5 stud 114.3)
what's the best shell to whack this into for CHEAP? R31 / R32?
basically just need car w aiiight gearbox/panels, and a busted motor.
apparently the old corrolla ( AE71 - I think ) can be made to drift really well without going overboard spending... Drop a 4AGZE into it and if that aint fast enough turf the supercharger and turbo it. As far as I am aware the Hilux diff and gearbox isnt to hard to install..
RB20det
GTT turbo
GTST injectors
GTT fuel pump
SAFC 1
umm..
http://nissansilvia.com/forums/index.php?s...60&hl=shell
http://nissansilvia.com/forums/index.php?s...13&hl=shell
http://nissansilvia.com/forums/index.php?s...36&hl=shell
Yeah 31, c'mon surely you've heard of Fatz, Easo, and the stuff that the Drift Battle Lads got up to with the wags a while ago :whistling:
10 minutes of my life not wasted.
Thanks.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
