Car is a 32GTR. Just wondering if anyone can give me some idea on what this rattle might be. I've already searched, but nothing seems to describe my symptom accurately.
The rattle sounds is a bit like when you leave your mobile phone on a hard wooden table and it vibrates, but with a more metallic sound.
- Does not seems to happen when I free rev the motor (i.e. gear in neutral) or at idle.
- Happens on and off, but occurs 80% of the time.
- Happens between 1000rpm - 2000rpm, but usually at around 1700rpm.
- Only happens for like 1 second, 2 seconds max.
- Seems to happen when motor is under load and in most cases, when the car is just going from standing still.
So to put it into a typical scenario:
I've stopped at the traffic light, car idling fine at around 1000rpm, light turns green and I take off nice and easy, rev hits about 1700rpm and the rattle comes on for a brief second, then goes away when the car hits 2000rpm.
The thing is, if I take off faster by reving the engine harder, then it either does not rattle or maybe it does, but happens too fast and I don't hear it. Based on info that I found on this forums and the others, it seems that this could be an indication of either
- Engine pinging
- Exhaust manifold shield rattle
- Early signs of spun big end bearing
- Turbo shaft play
What do you guys think? Any similar experiences or anyone knows what it might be?
https://www.sau.com.au/forums/topic/224894-strange-rattle/
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
