  • Replies 55
Posted Images
  • 3 months later...
  • 3 months later...
quick question
do the R34 GTR rims fit the GTT wiithout the need to roll the guards?
and what tyre width do u guys have at the front and rear?
thanks
Anyone can answer this? I have a GTT and just acquired some R34 GTR rims without tyres so now I need to know what tyre sizes to buy?
lol what are you bumping for???
lol
i love nice clean lines and am i fan of cars without spoilers.
BUT
an R34 coupe needs a spoiler a GTT or a GTR. i took my wing of my 34 and had it back on the next day. back looks to plain and simple without it.
but ye lower your car and it will look a million bucks.
stop badmouthin' Nismo spoilers!!!!!!!!!!!!! you just got to get the right one
in any case is that hideous thing in the previous posts really Nismo???????????
if the bl...dy uploads are working (which half the time they are not) then here's a pic of a genuine Nismo spoiler for R34 and its adjustable too- :banana:
^^^ with a spoiler like that, do you feel more down force or better handling? or they mainly just for looks?
wouldnt mind looking into one for the track.. if you can feel better handling
Edited by viet_boi
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
