1988 Nissan A31 Cefiro
120,000km's
Factory Manual 5 spd
RB20DET
Aircon been regas 3 moths ago
New receiver dyer
Car has original 120000km's on engine and chassis.
Genuine nissan timing belt & water pump done on 105, 000Km
Genuine nissan heater hose amd themostat
13 months registration in VIC till 28/4/2009
hyper gear TR43 Turbo (still under warranty) 225kw @ 1.4 bar (with dyno sheet)
Blitz pod filter
550cc Rx7 INJECTOR
300 Z AFM
040 FUEL PUMP
3" catback system
FMIC
side mount oil cooler and romote oil filter
Nardi Steering wheel
HKS boost gauge
Omoni oil temp, water temp & oil pressure gauges
R33 clutch fan (keep the car cool)
Fields SFC-Hyper R fuel control with display (1/4 time, rev and speedo)
Cusco coilover all around
R32 GTR Sway bar
D - Project caster rod front
Z32 4 pots caliper
rda slot discs
EBC GREEN front pads
Adr Approved Braided Brake Hoses front
17x8 drift tek all around
Front tyres Toyo R888 225/45/17 50%
Rear tyres Advan A048 235/55/17 50%
FRONT LIP AND DUCK TAIL WING
SERIES 2 TAIL LIGHT
HID
AP ENGINEERING PFC
PRICE DROP $11000 ONO
CONTACT ME FOR MORE INFORMATION
0433 409 011
WING
Edited by whyau1
https://www.sau.com.au/forums/topic/224915-cefiro-manual-pfc-for-sell/
  • 3 weeks later...
  • 1 month later...
can u pm me pics?
are u after a swap .
ive got a r33 skyline with a r34 neo motor, microtech LTX-12, Jic coilovers, big fmic, brand new 1000hp race/drift clutch, lightened fly, lock diff ( NOT WELD) sterio, 60mm alloy 3 core radiator, 17" wheels,
AND MORE
PM me if your keen.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
