yep i was there today saw the gtr go on the dyno!
although there seem to be alot of problems on the dyno the r35 wouldnt stay in gear to complete the runs took about 4-5 goes before finalli producing the 366kw atw
also saw the sau stand next to the dyno!
and i just read yesterday about the r32 gtr that beer baron was building with the crate motor! i saw it and read that piece of paper that said 2007 crate motor and i was like oic thats the one i read about!
I would hazard a guess that the announcer doesn't know what he's talking about.
There is another thread floating around about the Haltech R35 that was producing 355kw @ 15psi during testing of the ecu at Gas Motorsport. The std boost is 10psi so.......
And this graph from the Haltech website,
Edited by jonn
It is super impressive how much power they have gained with just tuning and boost increase. what's just as impressive is how quick it is on road/strip/circuit to begin with considering it's packing "only" 290awkw from factory. Who would think a car that weighs so much, and has 20inch rims with road rubber, and packs under 300awkw would be such a super car beater. It just goes to show that torque, and response and how the power is delivered is so much more than just a peak number. and it shows how good the chassis and gearbox is. I have driven the standard car and it blows my mind, with 60awkw more it would just be off the planet! :D
It is super impressive how much power they have gained with just tuning and boost increase. what's just as impressive is how quick it is on road/strip/circuit to begin with considering it's packing "only" 290awkw from factory. Who would think a car that weighs so much, and has 20inch rims with road rubber, and packs under 300awkw would be such a super car beater. It just goes to show that torque, and response and how the power is delivered is so much more than just a peak number. and it shows how good the chassis and gearbox is. I have driven the standard car and it blows my mind, with 60awkw more it would just be off the planet! :laugh:
when did you end up getting behind the wheel anyways richo?
Giants car was it?
hehehe, if you had just panned to the right at any time, you would have seen me sitting my lazy ass on the floor inside the cage :laugh:
Why doesn't anyone come say hi?! :laugh:
The deal with that was that when the operator put the pedal down, it was shifting it down a gear... dunno why...
The announcer doesn't really know what he's talking about ALL the time :laugh: but so many cars go by, who can blame him...
But one thing that was mentioned was that an aftermarket exhaust system they tried only netted them a gain of a few kw... i thought it was hard to believe with there being cats right in the dumps, but maybe you really need to push some psi through there before they start restricting too much... iono :P
but seeing the guys at GAS and Haltech were there in and around the car with the announcer during the dyno run, they wouldve told the guy the info he needed to blurb out
Maybe they did, but like others here they mistook "standard everything" as being the car completely untouched, rather than just standard hardware. Its a bit too late to correct the guy after he's said it.
There's already been a bit of news about the Haltech R35 GT-R, and their ECU does modify boost as well as the timing (and possibly fuelling).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
