Hey Richard, long time no see. how you been?
It sure was you, Jayce and Goran in the GT-R's (Jon, supafly, and chris in the gts-t's)
It was truly a spectacular entrance and my mates and dates had a ball on the trip out, definantly talked about for a while. Skyline convoy is always a good option :P you would already have three organised :D
last time i do anything for you!
:D
  • 4 months later...
  • Replies 95
Posted Images
Well its that time... Becs formal is on Wednesday (3rd Dec) and she has decided to go with my GTR. She isn't allowed to take a guy from another school (school rules not mine) and she isn't attracted to any of the guys at her school so she is going solo.
I was wondering if anyone wants to make it a little more special for her and join us to help make a little Skyline convoy. It won't take up much of your time because its not far from home here and its only dropping her at the church beside Trinity Christian School at Wanniassa. We could then go somewhere afterwards if you'd like... a mini cruise, drinks, eats, coffees, catch up.
The only catch is that she needs to be at the church by 5pm - I know its a big ask being so early, but it won't take long and will be fun to catch up after.
All models welcome.
Anyone interested?
:woot:
That was the next year, and that was pretty awesome :)
All models welcome.
Anyone interested?
I would be but I work till 7 :)
Thanks Guys
We're talking this Wednesday 3rd Dec... if you can make it, meet at my place at 4:30 and we can drive via Tuggeranong Town Centre (exciting I know LOL, other suggestions welcome) there won't be many of us, but it will make it a little more interesting.
Thats okay Paul, we'd love to have you come along if you change your mind, its no passengers, so not your "normal" formal run, more like arriving with a mini (ok very mini) convoy to make it a little more interesting.
Guys its really up to you, if you're not here when we leave, we'll understand, no pressure at all. But if you can make it, Bec (and us) will really appreciate it. She's a good kid and the school nearly didn't allow them to have a formal (strange school).
PM me if you don't have my address already. Thanks again :P
Yep, just a drive in, stop and photos as said and drive off. After the last 2 formals my mates daughter just went to, I would refrain from any mischief type behaviour... There has been police in both marked and unmarked at all of them.
The Eddies one that was at Rydges Lakeside ended up funneling all the traffic to the back of the hotel straight into awaiting police.
I just washed the car on the weekend and would like to help out Michele but as with the rest of the guys, I can't finish work early enough.
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
