Hey Richard, long time no see. how you been?
It sure was you, Jayce and Goran in the GT-R's (Jon, supafly, and chris in the gts-t's)
It was truly a spectacular entrance and my mates and dates had a ball on the trip out, definantly talked about for a while. Skyline convoy is always a good option :P you would already have three organised :D
last time i do anything for you!
:D
  • 4 months later...
  • Replies 95
Posted Images
Well its that time... Becs formal is on Wednesday (3rd Dec) and she has decided to go with my GTR. She isn't allowed to take a guy from another school (school rules not mine) and she isn't attracted to any of the guys at her school so she is going solo.
I was wondering if anyone wants to make it a little more special for her and join us to help make a little Skyline convoy. It won't take up much of your time because its not far from home here and its only dropping her at the church beside Trinity Christian School at Wanniassa. We could then go somewhere afterwards if you'd like... a mini cruise, drinks, eats, coffees, catch up.
The only catch is that she needs to be at the church by 5pm - I know its a big ask being so early, but it won't take long and will be fun to catch up after.
All models welcome.
Anyone interested?
:woot:
That was the next year, and that was pretty awesome :)
All models welcome.
Anyone interested?
I would be but I work till 7 :)
Thanks Guys
We're talking this Wednesday 3rd Dec... if you can make it, meet at my place at 4:30 and we can drive via Tuggeranong Town Centre (exciting I know LOL, other suggestions welcome) there won't be many of us, but it will make it a little more interesting.
Thats okay Paul, we'd love to have you come along if you change your mind, its no passengers, so not your "normal" formal run, more like arriving with a mini (ok very mini) convoy to make it a little more interesting.
Guys its really up to you, if you're not here when we leave, we'll understand, no pressure at all. But if you can make it, Bec (and us) will really appreciate it. She's a good kid and the school nearly didn't allow them to have a formal (strange school).
PM me if you don't have my address already. Thanks again :P
Yep, just a drive in, stop and photos as said and drive off. After the last 2 formals my mates daughter just went to, I would refrain from any mischief type behaviour... There has been police in both marked and unmarked at all of them.
The Eddies one that was at Rydges Lakeside ended up funneling all the traffic to the back of the hotel straight into awaiting police.
I just washed the car on the weekend and would like to help out Michele but as with the rest of the guys, I can't finish work early enough.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
