Hi everyone,
just wondering if i could ask a favour from any R34 owners out there with FACTORY XENON headlights (NOT aftermarket H1 kits to deal with butchered compliance headlights).
I've never actually seen what the factory lights are like at night and was wondering if anyone would be so kind to take a pic of their car at night, facing a wall, garage door, etc... preferably not parked too close to the wall/door.
Basically i want to see what the cut-off and beam pattern is like, etc....
cheers!
daniel
https://www.sau.com.au/forums/topic/224946-a-little-help-from-r34-owners/
  • 1 month later...
Mine were put back in after compliance and they are sweet i would never buy another car without them they are brilliant for night driving. Hope this is what you were after my camera sucks tho. The drivers side one points lower but they throw a huge beam and bright as f$#k you can barely look at roadsigns you drive past there that bright
Edited by AndyD
what year is your stagea?? i'd also doubt they are projectors.... OEM Xenon projectors look like this...
i appreciate the post ;) but every reflector assembly has a different light patern, so i was kinda chasing someone with OEM R34 shots. Having said that though, we might have diagnose something with your car that needs to be checked...
The more i look at the front pic of yours, the more i think they're not Xenon. You should be above the cut-off line there with the angle you took the front shot, but you can still see a fair amount of glaring. This is a hallmark of an aftermarket HID kit in a reflector assembly not designed for it. A Xenon bulb (D2s, D2r, etc) has a certain light "signature" and the reflectors are designed to suit. You put in an H1 or whatever globe, the "pattern" of light doesn't match up and you get flaring everywhere, hot spots, etc.
The front shot does make the light look too yellow to be Xenon, could just be the pics
Is there a way to check like a part number or something. They look a little yellow cos of the parker globe which sits directly below the xenon,plus my camera sucks really bad and it was taken with the flash on. When looking at them they really are a purple/blue color,im not doubting what your saying but the camera really doesn't do justice to how it really looks if there is a way to check let me know and i'll check it out as it was listed on the auction sheet as xenon's so if they aren't i will be just a little bit pissed off. Oh and it is a 1999 series 2 stagea
well i just picked my car up from the panelshop thisarvo n the replacement headlight they put on is HID but the one they didnt replace is ye-olde compliance hack job so ill try n get some photos before i get a replacement light. dont own a camera so have ta try n get my mates one.
My r34 has xenons, will try to take a photo tonight...but there are like 4 modes you can adjust the xenon.
I havent really worked out what these modes actually do except they kinda differ in height a little.
PM me if i forget. lol
Edited by JI34GT
Andy, they come from the factory with Xenons, same as virtually every R34, but because they're not auto-leveling and don't have a washer function, they don't meet ADRs and are removed during compliance.
The easiest way to tell is point the car near a wall and watch what they do when you turn them on - Xenons will light up a bit like a street light - take a few seconds to reach full brightness.
JI34GT - that knob is to adjust the height of the beam, nothing else.
Edited by Iron Chef
i have Xenons on my R34 and there excellent and give such a better light then standard. i can try and get a pic of mine today or tonight. but i would reconmend them. if ur thinking of getting a set.
But ill warn you now, a new set of R34 xenon headlights will cost min of $2500 or about $1200 for second hand set.
adam
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
