Hey Guys
I always loved 32 4 doors, so i decided to finally get one. Picked this on up fairly cheap, but needed some love. My plans are to keep it street regestered and tralor it to drift events. Anyway Mods listed below;
MODS
Manual Conversion
3 Puk ceramic cusco clutch
JIC Coilovers - 8kg front, 6kg rear.
RB25 Neo turbo
AM peformance Stainless Front/Dump pipe with Screemer
3" Cat back exhaust
600x300x76 Bar and plate cooler (will change to tube and fin eventually)
Generic Cooler piping
Apexi Boost guage
R33 GTR Rims 17x9 +30 all around with 215/45/r17 rubber
Future Mods
Shimm up the stock LSD
White Line Sway Bars fornt and rear
Front and rear strut braces
Adj Rear Camber arms
Adj Front camber arms
Adj Carster Rods
Oil Pressure, Water temp and Boost guages
GTR Front bar with N1 Slots
Full Re-Spray
and................................RIP SOME SKIDS!!!!!
The only pics that i have at the moment are shitty phone pics, but ill take some better ones later this week.
Hope you's enjoy
Edited by Lock_to_lock
https://www.sau.com.au/forums/topic/224953-my-r32-4-door-build-thread/
  • Replies 74
Ok not much of an update but meh.
In order to be a hekitc drifter you need to be part of a heckitc group of friends. So i got some stickers made up, purely for heckitc reasons. It fairly self explanatory.
Yeah same here, i wont be putting a kit on mine. Just GTR front. keeping it nice and simple
Well it doesn't look like ill be making it out to drift prac on July the 6th. Hopfully in the next few weeks ill get replacing the front seal, water pump and timing belt as well as shimming up the diff.
Ill keep this updated with any progress.
Cheers for the comments!
  • 3 weeks later...
Ok, bit of an update. Finally found a genuine gtr front bar, lip and reo :D
Hopefully will have the front seal, water pump and timing belt done in the next few weeks. Also got to pick up a few small things, order some sway bars and keep saving for re-spray!
once again, thanks for the comments! I really need to stop taking pics with pov phone camera. might take some nicer ones tomorrow. Not to sure where to mount the number plate, was thinking about passenger side above the vent?
Damn you your cars looking good, Making me want to spend money on mine. Which I'm trying not to do atm, apart from the essentials. Would like to know how much your respray costs when you get it done, as I'm looking at getting mine resprayed in bayside blue again, as the paint could be a bit better.
Paid the deposit on the 25 last night, should pick it up in a week. 75,000kms, motor is clean as. Comes with everything. Loom, ecu, afm, stock cooler and piping. cant wait! Keep your lids peeled back for updates!
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
