Update!!
Hey guys. thought i would update the thread.
I bought this car off the previous owner a few months back. I previously owned a black r31 coupe rb20 silvertop, but i had a minor mishap and ended up selling, so i now own this baby. I've got a few plans for it including some fresh paint, some more power and some handling upgrades.
Iv'e done a couple of minor things to the 32 since ive bought it, mainly cosmetic.
-Genuine Gtr bonnet (black)
-Genuine Gtr grille (black)
-Full amber indicators (Gtr look)
-Nismo gear knob
-Front strut brace
things going on the car in the very near future (already got, just gotta put on)
-Bosch 040 fuel pump
-GFB mechanical boost controller
-Remapped computer (jeff from the speedlab)
-New dash cluster
and here's a pic of it how it sits at the moment. Just ordered premium (CC) square plates front and rear for the complete jdm look.
Edited by Greasy
  • Replies 74
cheers man. hopin to eventually get a respray in the new year, while im at it get the guards rolled and lipped all round and fit some lower offset dish wheels :D most likely gonna go with a silver respray with a black roof. mmm hot.
BOSCH 040 fuel pump successfully installed today.
Much thanks to the tutorial in the diy section for 'Installing A Bosch 040 Fuel Pump Into An R32' thread by eXc. copied it exactly, worked first time no issues. :D
also installed new rear speakers, will finish the rest of the system within a week or so.
Now for-
rising rate fuel reg,
remap,
possibly 2 stage electronic boost controller, (profec b II)
twin 3" straight pipes from muffler back.
Iv'e Had a chat to a few people, rising rate fuel reg won't be needed, and electronic boost controller is only needed for higher boost applications (will only be running 11-12 psi through the factory neo turbo) or if i really wanted two boost stages but if i'm only gonna be running 12 psi max then theres no point in having dual stage, as the bleed valve will be safe enough.
Having thought about these factors, and from what people have said, coilpacks should be the next mod on the list as RB's are prone for having problems with them.
so that means the list is now:
Mechanical bleed valve
Remap > 11~12psi > 210kw+
Twin straight pipes
splitfire coilpacks. (eventually..)
The remapped ecu that i bought recently is tuned for a s2 rb25 running standard turbo, bosch 040, 3", cooler etc. same as what i have on 10psi making 209kw with a continuous power curve. I am taking the ecu with me back to jeff from the speedlab (local tuner who has a very good reputation for safe yet very good power figures) to get it set up specifically for my application running hopefully more around the 12 psi mark. so i don't think im too far off thinking that it should still make at least 210kw. we'll see what happens once i actually get it tuned. :P
Installed an autometer sport-comp boost gauge today ready for when i get it remapped. Next to do will be high flow cat and twin straight pipes (from the first muffler back) should look and sound a lot tougher. then remap.
  • 4 weeks later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
