Update!!
Hey guys. thought i would update the thread.
I bought this car off the previous owner a few months back. I previously owned a black r31 coupe rb20 silvertop, but i had a minor mishap and ended up selling, so i now own this baby. I've got a few plans for it including some fresh paint, some more power and some handling upgrades.
Iv'e done a couple of minor things to the 32 since ive bought it, mainly cosmetic.
-Genuine Gtr bonnet (black)
-Genuine Gtr grille (black)
-Full amber indicators (Gtr look)
-Nismo gear knob
-Front strut brace
things going on the car in the very near future (already got, just gotta put on)
-Bosch 040 fuel pump
-GFB mechanical boost controller
-Remapped computer (jeff from the speedlab)
-New dash cluster
and here's a pic of it how it sits at the moment. Just ordered premium (CC) square plates front and rear for the complete jdm look.
Edited by Greasy
  • Replies 74
cheers man. hopin to eventually get a respray in the new year, while im at it get the guards rolled and lipped all round and fit some lower offset dish wheels :D most likely gonna go with a silver respray with a black roof. mmm hot.
BOSCH 040 fuel pump successfully installed today.
Much thanks to the tutorial in the diy section for 'Installing A Bosch 040 Fuel Pump Into An R32' thread by eXc. copied it exactly, worked first time no issues. :D
also installed new rear speakers, will finish the rest of the system within a week or so.
Now for-
rising rate fuel reg,
remap,
possibly 2 stage electronic boost controller, (profec b II)
twin 3" straight pipes from muffler back.
Iv'e Had a chat to a few people, rising rate fuel reg won't be needed, and electronic boost controller is only needed for higher boost applications (will only be running 11-12 psi through the factory neo turbo) or if i really wanted two boost stages but if i'm only gonna be running 12 psi max then theres no point in having dual stage, as the bleed valve will be safe enough.
Having thought about these factors, and from what people have said, coilpacks should be the next mod on the list as RB's are prone for having problems with them.
so that means the list is now:
Mechanical bleed valve
Remap > 11~12psi > 210kw+
Twin straight pipes
splitfire coilpacks. (eventually..)
The remapped ecu that i bought recently is tuned for a s2 rb25 running standard turbo, bosch 040, 3", cooler etc. same as what i have on 10psi making 209kw with a continuous power curve. I am taking the ecu with me back to jeff from the speedlab (local tuner who has a very good reputation for safe yet very good power figures) to get it set up specifically for my application running hopefully more around the 12 psi mark. so i don't think im too far off thinking that it should still make at least 210kw. we'll see what happens once i actually get it tuned. :P
Installed an autometer sport-comp boost gauge today ready for when i get it remapped. Next to do will be high flow cat and twin straight pipes (from the first muffler back) should look and sound a lot tougher. then remap.
  • 4 weeks later...
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
