As the title states just curious if anyone else saw or bid on those Power FC's going on ebay through seller "euro_bella88" I found it to good to be true so i bid for the fun of it. ended up winning the bid. Didnt expect that. Not sure if i should go through with the sale.
yeah i have seen them on ebay to there is lots of people from china how sell them as well and they are fairly cheap like $900 for one and yes they are the real thing as well. if ya not to sure of them just pay through pal pay then ya got nothing to lose if they dont send or get lost ya get ya money back
guys can you please stick to the topic, maybe i should have stated that i did want the item and have intention of buying, just that after reading paypals fine print they dont pay out maximum amount if item does not arrive which doesn't even cover half the amount. i dont care what language where talking im not gonna loose out more then $500. i to am a seller and have been f**ked around many times. so please dont try and preach to me.
Sure.
here we go, whatever guys seriously. obviously my choice of words wasn't the best in first thread. would edit if i could but cant. end of the day you are no one to me so i do not have to explain myself to you. anyone else wanna have a go. go for gold :blush:
Noboby's attacking you fella, you made the post and asked for comments..now you wish you could edit it because it doesn't show you in a good light? Buyers remorse, too many beers?
The rest of your posts in this thread pretty much sum it up.
You're welcome :blush:
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
