Hey guys...
Need advice
Current Setup:
Rb26dett
stock crank R33
nismo bearings
ARP main, Head and Rod bolts
Eagle Rods (treated)
Cosworth Pistons
HKS Head gasket
Stock Head
Adj cam gear
Splitfire coils
N1 Water and oil Pumps
Tomei oil restrictor
Deep baffled sump
700*300*75 HKS intercooler
600cc Injectors
Apexi intank fuel pump
Power FC
3” catless exhaust
2 x Garrett GT2560R-10 GTR 400hp ball bearing turbos
2 x mesh pod air filters
Apexi AVCR boost controller
Installing:
Tomie PonCam Spec B
Tomie valve sping kit Spec B
800cc or 1000cc injectors
2 x Z32 AFMs
ATi 1000hp harmonic dampener
HKS twin power
Conditions:
- Must run on Optimax Racing (STD fuel)
- Must run 21psi or Less (I dont want a one hit wonder)
Will it be possible to hit low 400kw's at all 4 wheels with this setup and still maitain reliability?
and what am I missing? :blush:
thanks
G.
https://www.sau.com.au/forums/topic/224995-wanting-400kw-all-4s-on-a-r33-gtr/
Use of the car?
Setup is pretty sound. Head will need a little bit of a tidy up.
3.5" at a bare minimum for the exhaust, preferable 4" for the flow
you might need a set of coil packs depending on the condition of the ones you have now also
Use of the car?
The main use will be street with some track time.
Exhaust is a problem as my 3' is already 94Db and max in Vic is 90... so I cant go any larger.
Coil packs are Splitfire and HKS twin power CDI
What are people thoughts about going larger cam ie: tomei Procams 270, Lift 10.25mm IN and OUT
Edited by greggtr
Yeah you can, im 92dB, 3.5", recently passed with under 90 :blush:
So it can be done.
If your so worried about legalites with exhaust noise, id be more worried with every other single part on your car thats beyond legal and stands out like dogs balls
just because the exhaust is big doesent mean it has to be loud it all comes down to the mufflers you use. make it nice and quiet for the street. then you can get a straight peice of pipe made up to bolt on from the cat back with no mufflers for on the track.
you could make a cool pipe to exit out the side behind the door.
full noise! :blush:
regarding revs with the tomei spec B spring kit etc.. the redline will be 9000rpm
With other "non-legal" things on the car... well unless the Police crack open my engine, they can not tell thats its modified, externally with the exeption of the exhaust tip my car looks stock... and not a cop magnet... thats why I want to stay away from LOUD exhausts... My exhaust is a jap brand.. but the problem is all the exhaust shop will not guarantee that a 3.5 or 4" exhaust will be under or around 90db.. and to throw out $1000 I would rather look at it as a last resort...
Cams
Injectors
ECU
AFM
Pod/Intercooler
And thats just the beginning of what they can visually pick out in less than 1min. EPA are not stupid, nor are the cops these days
If you are going to worry about noise, but not the rest of the easy-to-defect items then you have your wires crossed
Cams
Injectors
ECU
AFM
Pod/Intercooler
I dont really want to change this thread into a "Street legal " conversation, but the tomei poncams are mild, and unless they are experts they can not tell they have been changed... injectors are mounted on a machines standard fuel rail and are black, so again they can not tell... ECU, well unless they start pulling my car apart they can not tell again... AFM are stock NISSAN z32's and unless they know part numbers they cannot tell the difference. Pods are mounted in a Air box hence legal, intercooler is not huge and can be passed as standard and changing an intercooler is not ilegal
Willt GT2560Rs will come anywhere near 400awkw? They're smaller than the GT-SS'.
my 2560's are -10 and are rated at (400hp each)
there are -5 (320hp) and -7 (350hp), most people have the -5 as a standard upgrade over the stockies and they can do low-mid 300kw@4W... So I figure the -10's "should" hit 400
Cant find 2560-10's on the garrett site,
I could only find 2560-9's 4's and 1's,
and the 2560-9s are smaller than the 2860-5s, which when pushed may reach 400rwkw. But yours may be running larger wheels or something, dont know.
If i was chasing over 400+rwks, id be looking at the 2860RS disco potatoes.
But your list of mods looks pretty solid, similar set ups on the rb26 dyno thread are making around 350kw.
Let us know how she goes when shes put together.
hey champ a mate of mine own a performancce shop n knows his shit when it comes to rb engines.He did a r34 gtr with simple mods like boost controller 3.5inch exhaust power fc injectors fuel pump cam gears garret 2560-5 turbos with 17pounds of boost and made 370awkws so i think maybe it could be done easily with abit more boost n maybe cams n a few minor extras but this car is very responsive hits full boost at 3500rpm n is n animal so it just depends on who you talk to.This is the set up im lookin at for mine but im also gonna fit a tomei oil pump to protect it abit more. a mate also making 360 awkw with very similar mods so it shouldnt be to hard to get the desired power out of your car
Whatever you reckon mate. Your wrong in so many ways im not going to bother.
3" exhaust is a choker, and being worried about noise is silly and you need a better exhaust shop if its that loud
hang on, so he needs a better exh shop if they cant guarentee a 3.5" will pass a noise test but you had to come on here looking for ways of getting yours quieter? hints to me maybe you also need to find a better exh shop or stop telling people its so easy
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
