Hey all.
I've got this strange problem with an R32 RB20. It has just an fmic, full exhaust, boost controller, etc. Still running the stock turbo.
Since it was bought, it's always had problems with missfiring under boost at higher rpm. We would change the plugs (Replace with BKR6Es gapped to 0.8mm) and it would drive well for around 1000-2000km, but then start missfiring again! Pull the plugs out, and they look fine, but put some new ones in and it drives well for another 1000-2000km?
I thought I'd try the BKR7Es on this car, as I use them in pretty much every other RB/SR with no issues whatsoever and something strange happened. The car wouldn't rev over 4000rpm. It was as if it was hitting a rev limiter? A really horrible missfire which would actually cause the revs to stop rising. We took the BKR7Es and gapped them all the way down to 0.6mm even and didn't help one bit! Tried taping up his coilpacks with electrical tape, and no help whatsoever.
After that we put another set of BKR6Es in and the car drove fine? But yet again, when 1500km ticked over, the missfiring came back.
Anyone have any ideas? :blush:
Thanks
Peter
Edited by Equinox
I'm having similar problems with my RB26DETT running a power FC with MAP sensor.
I might look into the ignitor pack also.
Mine only misfires when I hold the throttle steady above 4000rpm.
Very strange indeed.
I'll let you know if I find out what my problem is.
Rgds,
Grippy
Taping your coils isnt really a good fix for some coils anyway I had the same problem with mine so I tryed taping up the coils but didnt seem to work.
I gapped the plugs to .8 still missed in the end I just got some splitfires after that didnt even miss a beat also u dont have to change the gap to .8 i changed them back to 1.1 because my tunner said I wouldn't need them coz u would be creating enough spark with the splitfires.
How much Boost are you running?
have you thought of the fact that you are using BK plugs instead of BCP plugs. BK plugs are 2.5mm short than BCP plugs and might not be making a good connection up in the coilpack. the BCP plugs are the right size for a good contact on RB20 coilpacks
Exactly what i was going to say QWK32, get some BCPR6ES and try, a crook ignitor "shouldn't" really come and go, usually they work or they dont lol.
Change the plugs, clean the afm, clean the coils, check your earth to the coils and good luck finding the miss as there is nothing more annoying than an miss :)
Could also be the coil loom/plugs on the loom, my plugs were falling apart causing a really horrible intermitent misfire (started only when hot then got gradually worse to where it was there all the time).
Thanks for all the help guys!
QWK32 I never thought of that. I'll give the other plugs a go. And I'll try to source another ignitor pack to swap it with to give it a try.
However, I think you're on the money bubba. I pulled off one of the plugs and had a look inside and the little piece of plastic which holds the pins against the sockets on the plug was broken! I wired the wires straight onto the coil pack for now until I can find a replacement plug. Put some new plugs in and it's working fine, for now. :(
Again, thanks for all the advice. I'll see how it goes!
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
