This is a r33 turbo manual that has had mainly rear damage and front right guard,it still drives perfectly and is mechanically perfect,recently had the engine completely rebuilt.the car has an arc aluminium radiator and arc intercooler,hks 2535 turbo,enkei mag wheels,turbo timer turbo boost guage,aftermarket temp guage into top hose,rev speed meter apexi,gtr driver seat,3 inch exhaust,pod filtre,mines computer,strut in engine bay and through middle of car,japanese car cd/tuner,front and rear fibreglass spoilers damaged but can be repaired ,side panels also one damaged,would prob need a rear drivers quarter panel to fix,a front drivers bolt on guard,and the rear left needs panel beating.none of the frame is damaged at front mainly the fibreglass spoiler that makes it look worse than it is.no damage to bonnet or roofall glass perfect also
https://www.sau.com.au/forums/topic/225037-damaged-r33-95-mechanically-perfect/
thinking of selling complete first been offered $8000 but if i cant confirm that will strip it down and sell all the bits individually soon as all mechanicals are good only done 110k
what sort of suspension does it have?
its got aftermarket h/duty suspension all round ill check its name tomorow think it began with p and theres an adjusting spanner for them all
if you are separating, pm me a price for the turbo
i dont know what fair s/h prices for all these things are yet sorry will have to do some research,any expressions of interest for things would be appreciated and what you also think is a fair price would be good and the engine is running perfect i guess it pays to sell that first so a buyer can see it is running perfectly before all the bits around it are removed ,and the last post i meant passenger guard is good drivers side not
pm sent
im interested in the suspension! And about $500 ish is typical depending on type and condition!
think its called quantum coilovers im still trying to read the info on them they are not standard will look sunday again
$1200 for the rims depending on the condition of the rubber.. price on the arc radiater??
the rims are all in good condition enkei 17 inch ,rubber is down i cant really tell as im stipping it for my son think it looks about 25 % to me but could be more as im not sure how deep they are new on these tyres.how much are you offering for the lot including radiator its a 36mm type arc radiator
Which group of gypsies you hit ?
lol haha
good luck with the sale mate
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
