Garage Menace Posted June 22, 2008 Share Posted June 22, 2008 (edited) All, What is the best way to remove the speed limiter from a 2003 V35 GT manual? I have searched and all I have found are "speed cut defenders are available", however I'm not overly sure what they are, where to get them and any negatives associated with them. I am after the most reliable and cheapest method available without requiring a full ECU with the relevant tuning hassles. I do not intend to modify the car, just remove the speed limiter. I do not want to affect the fuel efficiency or any other tuning parameters the car. Any suggestions including brands, suppliers and installers (preferably in SA) would be much appreciated. Cheers. Edited June 22, 2008 by Garage Menace Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/ Share on other sites More sharing options...
WazR32GTSt Posted June 22, 2008 Share Posted June 22, 2008 what have you got planned in order to reach the speed limiter regularly enough to remove it? Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963011 Share on other sites More sharing options...
Chris Rogers Posted June 22, 2008 Share Posted June 22, 2008 think laterally. what does the ECU need to see to stop the car at 180... Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963105 Share on other sites More sharing options...
MaXiMuS007 Posted June 22, 2008 Share Posted June 22, 2008 Chris is making this into a cryptic crossword puzzle! Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963224 Share on other sites More sharing options...
br3ndan Posted June 22, 2008 Share Posted June 22, 2008 Just cut the wire for the speed limiter that or install apexi rsm. You may lose speed reading if ucut the speed limiter wire!! Or if the v35 doesnt have one, cut the speed o meter wire Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963261 Share on other sites More sharing options...
NISMO Posted June 22, 2008 Share Posted June 22, 2008 All,What is the best way to remove the speed limiter from a 2003 V35 GT manual? I have searched and all I have found are "speed cut defenders are available", however I'm not overly sure what they are, where to get them and any negatives associated with them. I am after the most reliable and cheapest method available without requiring a full ECU with the relevant tuning hassles. I do not intend to modify the car, just remove the speed limiter. I do not want to affect the fuel efficiency or any other tuning parameters the car. Any suggestions including brands, suppliers and installers (preferably in SA) would be much appreciated. Cheers. The speed cut defenders are what you're after. Just a colourful Japanese use of English. They will simply do exactly what your after and your cheapest option. Unless you decipher Chris' cryptic message and/or are as talented as him when it comes to electronics. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963283 Share on other sites More sharing options...
Chris Rogers Posted June 22, 2008 Share Posted June 22, 2008 (edited) Chris is making this into a cryptic crossword puzzle! I could have looked it up and told you which wire to tamper with.. need to make some of you think one point I did miss though - auto or manual? if auto it may fool with the shifting and toss a code or two. Edited June 22, 2008 by Chris Rogers Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963325 Share on other sites More sharing options...
MaXiMuS007 Posted June 22, 2008 Share Posted June 22, 2008 Chris, Would you really recommend the average Joe (or Max) to start cutting wires in their V35s? I'm with NISMO - Speed Cut Defender is what you are after. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963373 Share on other sites More sharing options...
Chris Rogers Posted June 22, 2008 Share Posted June 22, 2008 no. but someone saw my logic. to be honest IF you clipped the wrong wire there is a good chance the car wouldn't move. speed cut device would do nicely. unless somone can tell me the voltage and frequency the sender is operating at around that speed. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3963449 Share on other sites More sharing options...
Martin HKS Posted June 23, 2008 Share Posted June 23, 2008 All,What is the best way to remove the speed limiter from a 2003 V35 GT manual? I have searched and all I have found are "speed cut defenders are available", however I'm not overly sure what they are, where to get them and any negatives associated with them. I am after the most reliable and cheapest method available without requiring a full ECU with the relevant tuning hassles. I do not intend to modify the car, just remove the speed limiter. I do not want to affect the fuel efficiency or any other tuning parameters the car. Any suggestions including brands, suppliers and installers (preferably in SA) would be much appreciated. Cheers. HKS make a SLD for this. $445inc. Cheers Marty Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3965528 Share on other sites More sharing options...
br3ndan Posted June 23, 2008 Share Posted June 23, 2008 Cutting wires doesnt require too much skill.. and if you cut the wrong one, then just solder it back again. Ive clipped and spliced wires on my r33, when installing my apexi rsm to get rid of the speed limiter. Not that hard, the apexi website gave me a diagram explaining what wire was what. Took about 30 mins to install. and it worked perfectly! =) Don't be too afraid to play around with your car! Its all about learning! hehe Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3965574 Share on other sites More sharing options...
MaXiMuS007 Posted June 23, 2008 Share Posted June 23, 2008 The main problem is the V35 is so complicated - much more than an R33.. You clip the wrong wire and the car is finito (ask some of the others here). I'm definitely not game enough Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3965847 Share on other sites More sharing options...
br3ndan Posted June 23, 2008 Share Posted June 23, 2008 Yeah im not surprised the V35 is more complicated... its a much newer car. R33 is complicated enough for me! haha. Anyway good luck! But unless you gonna track it, cutting the speed limiter is not really needed. top speed limit in WA is 110kmh. going 180kmh+ on public roads is just f*cking stupid. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3965932 Share on other sites More sharing options...
Garage Menace Posted June 23, 2008 Author Share Posted June 23, 2008 (edited) Everyone, Thanks for the help, I think, though some of you are taking the piss... Chris, I will freely admit I know nothing about car electronics, and have neither the time or inclination to learn, hence my question. Thatz where experts like you come in. Bombs and bullets, camouflage and concealment, rules of engagement, and fire and movement are my bread and butter... Everyone, I welcome your continued input, and if anyone can advise of the cheapest reliable speed cut defender it would be appreciated. Cheers. PS. Itz for the track. I'm not an idiot. PPS. Chris, itz a manual. Edited June 23, 2008 by Garage Menace Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3966691 Share on other sites More sharing options...
br3ndan Posted June 23, 2008 Share Posted June 23, 2008 haha, glad to hear ur not an idiot i would go the apexi rsm to get rid of the speed limiter. Then you also get other features such as lap times / Qtr mile times and power output ratings (just a few of the features it offers)! I got mind 2nd hand for 150$ plus the G sensor, which senses how much G force the car is experiencing.. helps to make more accurate readings. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3966709 Share on other sites More sharing options...
GT-R LM Posted July 1, 2008 Share Posted July 1, 2008 Unless your name is Chris Rogers DONT go slicing into wires on your V35 it can get very messy really fast as it has been said Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3983953 Share on other sites More sharing options...
Chris Rogers Posted July 1, 2008 Share Posted July 1, 2008 hehe! I'm not perfect you know Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3983971 Share on other sites More sharing options...
GT-R LM Posted July 1, 2008 Share Posted July 1, 2008 yeah but if you cut the wrong wire you end up somehow fixing the thing, which is something we mortals cant do or understand Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3984017 Share on other sites More sharing options...
WazR32GTSt Posted July 1, 2008 Share Posted July 1, 2008 chris, i've seen you work - you could easily fit into the nissan factory your wiring is that perfect, all you need would be to shrink to be about a foot smaller and turn a little asian and voila! Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3984030 Share on other sites More sharing options...
Chris Rogers Posted July 1, 2008 Share Posted July 1, 2008 tell that to one of the guys I do work for. have a van here (nissan thing) that I have to totally rework for htis market. has two screens and he wants the LOT to work here. so nav,tv,dvd, radio and a few extras. it has to be zoned as well. have it for as long as I need it thank god but its fun. put it this way I have a scope,sig gen,meter out pinning the thing out. Link to comment https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/#findComment-3984523 Share on other sites More sharing options...
