All,
What is the best way to remove the speed limiter from a 2003 V35 GT manual? I have searched and all I have found are "speed cut defenders are available", however I'm not overly sure what they are, where to get them and any negatives associated with them.
I am after the most reliable and cheapest method available without requiring a full ECU with the relevant tuning hassles. I do not intend to modify the car, just remove the speed limiter. I do not want to affect the fuel efficiency or any other tuning parameters the car.
Any suggestions including brands, suppliers and installers (preferably in SA) would be much appreciated.
Cheers.
Edited by Garage Menace
https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/
All,
Cheers.
The speed cut defenders are what you're after. Just a colourful Japanese use of English.
They will simply do exactly what your after and your cheapest option.
Unless you decipher Chris' cryptic message and/or are as talented as him when it comes to electronics. :D
Chris is making this into a cryptic crossword puzzle!
I could have looked it up and told you which wire to tamper with..
need to make some of you think :D
one point I did miss though - auto or manual? if auto it may fool with the shifting and toss a code or two.
Edited by Chris Rogers
no. but someone saw my logic.
to be honest IF you clipped the wrong wire there is a good chance the car wouldn't move.
speed cut device would do nicely. unless somone can tell me the voltage and frequency the sender is operating at around that speed.
All,
Cheers.
HKS make a SLD for this. $445inc.
Cheers
Marty
Cutting wires doesnt require too much skill.. and if you cut the wrong one, then just solder it back again.
Ive clipped and spliced wires on my r33, when installing my apexi rsm to get rid of the speed limiter.
Not that hard, the apexi website gave me a diagram explaining what wire was what.
Took about 30 mins to install. and it worked perfectly! =)
Don't be too afraid to play around with your car! Its all about learning! hehe
Yeah im not surprised the V35 is more complicated... its a much newer car.
R33 is complicated enough for me! haha.
Anyway good luck!
But unless you gonna track it, cutting the speed limiter is not really needed.
top speed limit in WA is 110kmh.
going 180kmh+ on public roads is just f*cking stupid.
Everyone,
Thanks for the help, I think, though some of you are taking the piss... :)
Chris, I will freely admit I know nothing about car electronics, and have neither the time or inclination to learn, hence my question. Thatz where experts like you come in. Bombs and bullets, camouflage and concealment, rules of engagement, and fire and movement are my bread and butter...
Everyone, I welcome your continued input, and if anyone can advise of the cheapest reliable speed cut defender it would be appreciated.
Cheers.
PS. Itz for the track. I'm not an idiot.
PPS. Chris, itz a manual.
haha, glad to hear ur not an idiot
i would go the apexi rsm to get rid of the speed limiter.
Then you also get other features such as lap times / Qtr mile times and power output ratings (just a few of the features it offers)!
I got mind 2nd hand for 150$ plus the G sensor, which senses how much G force the car is experiencing.. helps to make more accurate readings.
tell that to one of the guys I do work for. have a van here (nissan thing) that I have to totally rework for htis market. has two screens and he wants the LOT to work here. so nav,tv,dvd, radio and a few extras. it has to be zoned as well. have it for as long as I need it thank god but its fun. put it this way I have a scope,sig gen,meter out pinning the thing out.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
