hey ive owned a r33 4 2 years now and want to upgrade it
1.how much power 4 a save but fun tune
2.what to do 2 get that power
i already put a intercoolerthats it
260-300rwkw
exhuast
cam gear
ecu
ebc
new turbo
infectors
fuel pump
the list is endless depends on how you want your car to drive
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3963436
260-300rwkw
exhuast
cam gear
ecu
ebc
new turbo
infectors
fuel pump
as above plus
splitfire coil packs
airfilter
turbo timer
clutch
you also may want to look at the handling if you havent already, i.e. suspension, brakes, etc.
all up yor looking at around 10k for quality parts and labour, and another 5k for handling
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3963478
as above plus
airfilter
turbo timer
clutch
:) thanks guys you can get most that stuff off this site aye might aim 4 270 kw only have stock internals and as im in townsville qld theres not many places to get a rebuild trying to get a power f c atm and my fuel pump is playn up so thats what im hav to get strait up any suggestions on a fuel pump seen a gtr in rb25 craddel 4 100 buks then seen a brand neew 255 lb walbro 4 $160 hav 2 custom urself to fit
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3965789
get a bosh 040 they are pretty much the most known for quality i have heard heaps of bad shit about walbro tho .but gtr pump should be fine
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3968858
hookt up a bosh 040 on a 33 braket wit plug every thing $120 should be good no pay pal. did bank deposit scary how am i going to get my power fc there like $1200 120 is not so bad to get ript off but 1200 is lol hav to find 1 wit pay pal or some thing SAFE 1 st time bought on line yet.
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3972024
Use the search function, this topic get's asked every week.
For example if you search rb25 turbo upgrade , you would have found this: http://www.skylinesaustralia.com/forums/Rb...mp;hl=rb25+dyno
Find the turbos that you find fit your power requirements, then search some more and you will be able to make an informed decision about which one to choose.
And secondly (i mean this in the nicest possibly way), can you please type in normal, understandable sentences.
cheers
https://www.sau.com.au/forums/topic/225071-upgrade-r33/#findComment-3972061
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
