Hi all,
I want to source new, or get my existing interior trim re-finished. The i am referring too is the plastic trim inserts parts around gear shift, and the entire dash.
Is there a company that offeres some soft of re-coating, or re-finishing to restore it to perfect condition?
I dont want some crazy custom colour or bullshit looking carbon fibre finish...
Cheers,
Ian
https://www.sau.com.au/forums/topic/225072-interior-trim-re-finishing-r33/
I thought it wasnt paint though. Rather some sort of coating. Seems to attract dust very well not that that is a good thing. I just figured there was a propper way, not a back yarder way of doing this..?
I think the plastic is just painted, just not a normal kinda paint.
seen many skyline interiors resprayed to look better then ever, and like said above it costs alot less. I did it on my VL, full repsray of every bit of dash and probably cost me less then 100 bucks. 3 years later and it hasnt faded, cracked or even marked
The factory plastic paint on r34's is shocking, so I repainted mine and came out looking better than new,
all it took was a few cans of paint and primer, a top coat and some prep work before painting,
took all but a lazy weekend to do (let parts dry overnight)
Ok guys thanks for the info. Im going to be doing some prep work in a few weeks on my other car for major re-spray work, so I'll do the GTR trim at the same time ... I might even post up the before and after pics if I dont turn it into a complete balls up!
It's very easy. here are some quick pics I snapped just now in the dark of what I done with mine.
We have a spray booth at work, and used auto paint to spray it, along with another two coats of clear.
nicely painted plastic interior + leather gear and handbreak boots from an sau user + blue LED globes for cluster and A/C controls from another sau user =win
Thats a GTS-T right? There interior trim is a little diferent. The GTR trim has a sort of soft coating on it rather than a hard finish normally. I found this out when I bought a replacement light switch trim part off ebay and noticed the trim coatings were completely diferent to my GTR.
Either that... or what is already in my GTR is not stock...
Dont you find all that blue light a bit much when your driving at night?
Has anyone else got more pics?
Cheers,
Ian
doxximus, what colour is that? I'm looking at respraying mine soon, and I wanted something like that.
Mine is red at the moment, I thought it would be cool... but now I think its kinda gay. Plus the spray painter was retarded (it was me :D)
Ian, that covering is stock. Looks ok, but mine was peeling off. But it took me about 4 hours to scrape it all off with a spoon!
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
