im sick of replacing axles
broke ANOTHER axle....f**k
this was the 2nd lap, in the rain, at Nikko
what is thicker at the mounting surface that will fit out cars?
i have a 180sx axle as a temp replacement. that one was a silvia axle.
any ideas?
https://www.sau.com.au/forums/topic/225080-what-thicker-axles-can-i-use/
you are running a s14 subframe arent you. did u break any before u did that mod. i see that it is the cv joint that has gone all destructo on you. is it possible that the narrower track has changed an angle that the axles rotate at and put to much strain on the cv's. im thinking of putting the s14 subframe in my car to reduce the track and get my tyres to fit under the guards a little better but im worried that it might bring them to close to the suspension or will the struts move inwards enough to keep the same clearence.
sorry i cant help you out with any thicker axle ideas
nah this was in a new stagea subframe.CV boot messed up becuase the part it attatches to is mangled....ill have some more detailed pictures today when i unload my car from the trackday
No, see I was going to say that you should look into getting a GTR rear cradle (coz the driveshafts need the centre to use) but its not really the axle you need to strengthen, its the CV joint. It may still be worth looking into.
The problem you have, is the running gear in the S1 is the same as the R33 GT-4 and they don't have the same "meatiness" about them as the gtr, because the R33 GT-4 was only ever released with the NA RB25. To prove this, just compare a front driveshaft from a GTR to a stagea, and you will see that the stag ones step down in diameter before the diff, whereas the GTR ones don't.
really....thats interesting
but converting to GTR subframe, arms, suspension lowers, diff is out of hte quetsion
I can get custom axles/cv/drievshafs for 500.00 in the US that are super duper beefy
i was trying to find maybe a skyline, or other axle that would hold up a little better without HUGE changes
anyone have this happen to them?
i did the same thing, though i snapped the axle itself, i converted to 32 gtr rear diff and axles/hubs/brakes :) have a read ofthis thread i did years ago on the conversion... (that was my old username)
the gtr uni joints are massive compared to stagea ones, theres some measurement figures in that thread if u take a look...
http://www.skylinesaustralia.com/forums/st...diff+conversion
on the gtr size axles/unis ive ran a 11.3 at drags and done 20-30 8500rpm launches on them and not broken any yet :) the side which is custom length is also made at home by my old man and its lasted which is funny as i expected it to break years ago. Im currently putting over 550hp at wheels through the stock gtr gear.
Edited by unique1
like i said
i can get massive custom axles for that much
no reason to do all that work.
im wondering if maybe R33 GTST may be bigger, or cefiro, or some other massive car
or even 6bolt vs 5 bolt axles
All of the following have the same size drive shafts (or axles)
S13 (and 180sx), S14, S15, R32, R33, A31, C33. I can't comment on R34, but I suspect they would also be the same.
All of them are the same size (though some may have 6 bolt pattern as opposed to 5 bolt pattern where they join to the diff), except for the GTR models. The GTR has a thicker driveshaft, and as a result a larger spline where it enters the wheel hub.
You don't need to change the diff/subframe etc to use GTR driveshafts. Providing your car has 5 bolt pattern on the driveshafts, the GTR ones will bolt up to your diff. Then the only problem is the spline difference.
I can't comment specifically about stageas, but I would bet my left nut it is going to be the same as the skylines/silvias in the design of the rear hubs.
There are 3 parts to the hub assembly.
The hub carrier (or upright), is the cast iron piece that your suspension arms and struts bolt onto.
The backing plate, contains the drum style parking brake (if your car has one) and acts as a stone guard to the brake rotor
The hub itself, holds the wheel studs, the bearing is contained inside the hub and the spline from the driveshaft is engaged with the hub to transfer power to the wheels.
On all of the above mentioned models, the hub assembly is designed the same way, that is the hub is bolted onto the upright with 4 bolts and the backing plate is sandwiched between the two.
The R33 models and the GTR's use a different method of bolting the suspension arms to the upright, which makes them incompatible unless you want to go swapping your whole rear end out. But, they still both use the same method to bolt the hub itself to the upright, which means that the GTR hub will bolt onto an upright from any of the above mentioned models.
Edited by daisu
its fixed
the diff was all f**ked up
the guy i bought it from put he wrong output shafts, ring gear and a few other things
after 350 bucks its a brand new diff pretty much, no more clunking and im bound to bet no more broken axles
  • 1 month later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
