Anyone Need Some Pallet Space? Japan -> Australia
My friend is back in Japan for the next 6 weeks for Uni Holidays. She will be packing up my 2 sets of track wheels for me and sending them back to Australia. If anyone wants to share some pallet space let me know and I will forward you her contact details. I think there will be room for a couple more sets of wheels on my pallet.
She does not want lots of questions from timewasters. She can help people that have bought big items from Yahoo auctions etc and dont know how to get them back to Australia. I think she will be doing some pallets for other people but its all being charged to my TNT account so I will be able to give some guide price as TNT charge me.
She does have a forklift at her Fathers business in Japan for loading pallets but she does not want to be doing very heavy items (Engines, Gearboxes) as its not worth the effort (Unless you want to make it worth it for her)
Parts would need to be sent to Tochigi (2 Hours from Tokyo)
My pallet is coming to Brisbane, and she is doing a couple to Goldcoast for someone else. These are coming AIRFREIGHT so wont be cheap but will be fast (Within 2 weeks)
I had an RB26 HKS Crank, a set or KTS Coilovers and some smaller parts just sent over and the total was 62kg
I was charged $700 by TNT which I didnt think was very cheap as it was a small package.
EMS(Air Mail) is not much more expensive. 62kg would cost $820 but the problem with EMS is the maxium of 20kg per parcel and the Crank was 26kg so I had to use TNT
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
