I have a full r34 GTR style fibreglass wide body kit for sale
+30mm front
+50mm rear
Was gonna wide body my 34 but have recently sold the car so wont be doning it now. I dont know the brand.
$800 (will get pics up tonight) prefere local buyer
R34 C-West brand new eyelids - $120
GT Wing - $150
All parts were to go on my r34 but bought a house and didnt end up putting them on the car and then sold it.
0412978740 - John
Edited by kairazy
Im not sure what brand, I bought it off this site a few months ago I believe its a custom made one by a company in Queensland. The build quality looks goos as it is thick fibreglass and it lines up well with the car.
  • 8 months later...
hey ricca where did you buy your fronts fenders im after the same ones?????
is it true that GTR front guards are the same fit as GTT's????? (coming from a GTT ofcourse)
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
