I have just finished wiring in my resistor pack for use with VR4 440cc injectors. I have fuel but no spark so i assume i've stuffed something up somewhere. The coil packs have power, how do check that the igniter (transistor) pack is getting/sending a signal?
I am running a gtslink computer and the car was running fine before the injector upgrade.
Cheers
I had the same problem
What I did was check each wire running to the resistor pack with a multimeter
With the ignition on, earth the multimeter (battery or what ever) and touch the other end to the wire your checking, should show +12v
Easiest way is to stick a sewing pin/needle into the wire your testing, then touch the positive end of the multimeter to the pin/needle
You need to identify weather the the resistor is getting power, if not then work backwards
Check the resistor, then check the wire you hooked up for the power, if there is still no power there check the power wire on the original loom and make sure its the correct wire
If the wire has power then check your connections/soldering. As the wiring does sit a bit tight and if its heavily taped, theres a chance the connection/some connections could have broken
Also make sure the resistor pack is good, not sure how you can test the pack it self
Hope that makes sense
"You need to identify weather the the resistor is getting power, if not then work backwards
Check the resistor, then check the wire you hooked up for the power, if there is still no power there check the power wire on the original loom and make sure its the correct wire"
cheers, but the resistor pack for the injectors has power and the injectors are working, however it's the spark that i'm missing so i'm wondering about how to check the igniter/transistor pack wiring
I have done some more work into finding out whats wrong, so far this is what i've found:
Coil packs have power
CAS has power
There is continuity through the loom from the CAS to the computer to the transistor (ignition) pack to the coils
During cranking the computer is putting out 2-3V to the transistor pack but the book says it should only be .2-.3V. Can anyone confirm if either of these values are correct?
  • 2 months later...
check to see if the ignitor pack is earthed properly.
btw my car is having spark problems atm i ve narrowed it down to a computer problem but i got a lend of some coilpacks and an ignitor pack and my car wouldnt even start with the replacement ignitor pack.
i seen it taken off another rb20 tried it on mine and wouldnt even start b4 taking it back and puttin it on the other car watching it start quite happily first click.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
