I will reprogram a 300ZX ECU for my RB25DET / Silvia, cause I can't find a R33 one(I live in Canada), and cause I can't reprogram R33.
So my question is, what are the stock timing map like?
I guess it will be very close to RB20DET , does it make sense?
I already got the RB20DET...but I would prefer to make sure that they are like RB25DET.
Also, does anybody as the firing order for RB25DET ? (I have to compare with a 300ZX engine..if there are not the same, I will switch injector and coil pack wiring.
There is an R33 Ecu for sell on ebay: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...&category=31250
Try getting 95 model as they have better fuel maps. I got 204 rwKw with stock 95 model ECU and stock turbo.
Lippo: Yes, it will probably go better with a 95 model ECU
S14Drift: The Daughterboards are not easily available and expensive. Badbiki doesn't have one, they are more complicated. You can get a new Hitachi H8-534 CPU from www.grid.co.jp and program it with new maps but it's like $300 windowed (reprogrammable) CPU and that's not all you need.
Sorry but I don't read japanese....
I have an eprom programmer, eprom eraser...and all that, I have been tuning SR20DET in Montreal(Canada) for almost a year now...
I can get a 300ZX ECU for less than 100 Aus...and then reprogram it... so paying 100$ for something I can't retune doesn't make sense to me.
Did the R32 RB20DET had the VTC too ? if so I can probably buy on of these (cause the have eprom on board) and tune that?
I would prefer a RB ECU for only one reason, they have 2 knock sensor input...and the 300 ZX only has 1....
S14Drift:Try this if you can't read Japanese, it will give you a rough English translation: http://babelfish.altavista.com/babelfish/u...ml%2F28_07.html
The Rb20DET don't have VCT. That is the biggest problem in adapting Rb20DET ECU to RB25DET engine. Some people have done it by adding an additional board with a specially programmed PIC microcontroller and a transistor to control VCT.
Would you be able get me one of those 300ZX ECUs for less than $100 AUD?
The best place is Ebay.com
There is a lot of these ECU for sale (at least 3 to 5 per week), some went for 38 $ US, and the last one I missed went for 43$ US...
If people don't want to ship it to Australia, I could have it ship here in Canada, then ship it back to you :)
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
