Hey people
Ill be getting a second hand r33 gtr fuel pump for $100. A few questions regarding the fuel pump are is it different from an r32 gtr fuel pump (i dont want to get an r32 gtr fuel pump thinking its an r33 gtr fuel pump)? How can i identify that its an r33 gtr fuel pump?
Also what should i do to it before installing it (such as changing the sock thing etc) and is it a direct bolt on?
Thanks.
https://www.sau.com.au/forums/topic/225193-r33-gtr-fuel-pump-in-r33-gtst/
hey dude, I thought all the gtr's were the same apart from the 34 mayb they arnt, apart from fitting I have herd they are a c#n* to get into the standard pump cradle but it can be done and worth it in the end! Good luck buddy
Hi , Doughboy here sold me an R33 GTR complete drop in fuel pump assembly and it replaces the R33 GTST's one entirely , literally one out one in .
One thing you'll notice is the slightly elevated pump noise but it's not a biggie . I get the feeling that R33 GTRs used a different fuel pump voltage control unit so they may have dropped the voltage a bit lower than R33 GTST's one does at light loads . In my car the pump rises to full voltage at very small throttle openings .
Cheers A .
Hey thanks for the replies
when you say assembly, did you mean the whole bracket thing? I think im just getting the pump but i dont know. If i dont get the assembly will i have to modify mine or does it come as one piece? Also did you replace any parts on it?
thanks
  • 3 months later...
hey
im lookin for an r33 gtr complete to drop in and was wondering the same thing? are there any differences between 32 and 33 gtr?
if u buy a complete r33 gtr pump, is it a complete drop in/change over, no hassles?
is the standard gtst pump voltage alright?
anyone got pics of the 2 just to see the difference??
cheers
I didn't take pics at the time and don't quote me but I think the R33 GTR pump sits lower on the bracket than the 33GTS25T one does - did it a while ago .
I know someone that fitted an R32GTR pump into an R33 GTS25T and it was a bit more fiddly to make work .
If I was doing it again I'd def get the whole R33 GTR assembly and fit it to the std R33 GTS25T fueltank .
Cheers A .
  • 1 month later...
R33 GTR pump in a gtst is good.
Can't say much about it seeing as mine was fitted by a mechanic, but i had the stock pump, a bosch 040 and now the gtr pump in my r33 gtst. I'd say it has the power capacity similar to the 040, but it's probably more reliable.
It also sounds good, whirring away, compared to the other two pumps. If you stick your head under the car it sounds really noisy though, it's a big buzzing sound.
But try get the whole assembly if you can, beats stuffing around trying to fit it.
If you don't have a better option i'd recommend this mod.
  • 5 years later...
There are much better pump options these days.
exactly!!..
why waste $100 on a 25yr old pump with god knows how many kms on it when for a 150-200$ you can get a brand new walbro or something that will outperform it...
GTR pumps aren't worth 20$ these days...
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
