i'm hardly ever home at the times they are open ... i may go back to unisa gym ... hey can u go get pricing for a years membership there?? if its good i might consider joining back and just going on the weekends and weekdays i will go somewhere else cause its too much bother going to town just for the gym ...
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-486925
I think the pricing is roughly the same. I think UNISA students it's a bit under $100, other uni students probably $140 and for others (like me) costs me $170/year.
You should try find a gym where you can buy sessions. Like 30 visits for $XXX. That way it saves a bit of money, and you can go whenever you like. Not worth paying for a year if you only go once/week. Well, it's not bad actually as it's damn cheap anyway.
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-486935
I am talking about the one in the city. I know a few of the people behind the counter there, but not Brett. I don't think the Mawson Lakes UNISA gym pass can be used in the one in town because my friend has membership at Mawson Lakes and he has to pay whenever he goes to the one in town.
The one in town is pretty small, but has enough range of free weights to keep you amused. If you want to go for classes, I'd go somewhere else seeing that they only have 3-4 classes/week. They may have more when the warmer weather comes round, but not entirely sure. The gym is usually pretty packed, especially on mondays.
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-490179
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
