My car will sport this kit at one point in my lifetime. This I solemnly swear.
BN Sport, URAS, TBO, Aeromaster, Final Konnexion, D-Max.... y'all can GTFO. GTO-RS win.
That is all.
Now... here's the porn:
https://www.sau.com.au/forums/topic/225203-fk-yes-i-am-in-love/
whats with the trailer lights stuck on the headlights as indicators lol and shitty welding around the strut towers meh the kit dosent do much for me im afraid
Trailer lights stuck on the headlights as indicators...? Don't know what you are smoking but all I see is factory cefiro indicators.
Shitty welding around the towers is stitch welding (aka seam welding) improves structural rigidity, agreed the welding could look better but meh.
I think the kit would look better if it wasn't soo low to the ground, and the actual car was lower.
Guest a31rb25
zomg... A31RB25... its the same front bumper as the one in your avatar. What is it?
it's not the same front bumper. the one in my avatar is an old Workshop X front bar from NZ. doesn't have the same GTR style air intakes in the centre of the bar as the GTO kit, nor does it have the same air intakes either side of the bar (as far as i can tell). the WSX kit also appears to have a smaller section above the cooler. both look to be based on the R33 400R kit, as somebody else mentioned
the GTO bar would look so much better in 1 colour (the rest of the kit probably would too)
Edited by a31rb25
hehe guess I'll just settle for the Workshop X fronto bamparu. not a fan of their chunky sides and no rear look tho. wish someone local made some sideskirts that didn't come out at 45 degrees like Uras n BN etc. like a vertex I suppose.
Guest a31rb25
the WSX kit is still made them. they updated the design a few years back, there's a shitload of pics of the newer front bar getting about, pretty sure most people on here would have seen a pic of one on a laurel or ceffy in NZ.
when i looked into getting one the kit was approx $800 and that was without a rear bar, and before freight.
Edited by a31rb25
I like it. Looks tough and a bit different.
The SR is a bit gay, but it has a nice trust snail hanging up off it so it makes up for the SRs gayness.
In all, a freakin tough looking car. Those pics dont really do it justice.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
