Ive just built a 25/30 and want to upgrade the turbo to something a bigger. Currently i have twin T3/T4s and am thinking about something like a GT42 or GT45 or T51r.
Does anyone run any of these turbos on a 25/30 or 26/30? I want to use this on the street but mostly drags.
What revs do they start making boost and when is full boost??
Im not really worried about a bit of lag as i will be running nos to help bring it on boost.
I will have a rev limit around 8000rpm
https://www.sau.com.au/forums/topic/225208-2530-turbo-options/
I can sell you my T04z setup if you can find me a GT35 (GT35r, GT3540, etc) setup.
All the turbos he mentioned are much bigger than a T04Z, I suspect he is shooting for a different target to what your T04Z would.
Here is a dyno plot from an R34 GTR running a GT4202R on an RB30DET (cammed 26 head):
Thanks for that Lithium. It looks like the GT42 will go alright.
Has anone used a GT45 on a 3lt??
And the T51r has been done before. But they do sound awesome.
What are my options from a different brand of turbo. Turbonetics???
Yeah the GT4202R is on a full weight R34 GTR that has only done one run down the 1/4 which was far from clean and did a 9 "off the trailer" with an H-pattern box. It will go faster....
What do you mean by "sound awesome", the concept or the actual sound of them?? If you mean the whistle, GT40, GT42, GT45 etcs all have the same kind of sound due to the anti-surge compressor housings :) As alternatives I believe a Turbonetics T76 or GTK1000 are in the same territory, as with Trust T88. All the typical 1000hp beasts. There is a really rare IHI RX8 for sale in NZ at the moment, I believe 1200hp rated... could go for that and be one of very very few. Unfortunately you'll never get a straight out answer on what exactly to expect, as I for one know of no one aside from maybe Indy race cars which have used them.
Here is the R34 with the GT42R doing its run to get an idea of what kind of ride you could be in for:
GTK 1000 could be a go. Is anyone here using one of these??
lots of people in the us using them on 2js should be comparable to a rb30 results wise
though they are pretty new so there wont be thousands of them to look at
Im using a t70 which is a garret replica, (couldnt afford the genuine item :) ) Its rated to 700hp, 40psi, externally gated and is of considerable size :D A friend of mine used one on his wrx (shudder) and was getting boost by 4000rpm. So hopefully il spool up around 3000rpm and listen to it whistle all the way up to redline :( When funding allows il upgrade to the t51r.
What other turbos are people running when using a big single???
What power range exactly do you mean?
Check out this site - possibly a bit out of date but has some listed:
http://t04r.com/turbos.php
These days there are neat things like the Garrett GT4088R and GT4094R, and in NZ there was or is a IHI RX8 which is an ~1100hp really flash thing.... they are basically used on indy cars.... that'd be interesting to see on a Skyline haha
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
