what??? are you on crack?
Seriously...just installed one on my r34...Cusco...you dont have to cut anything....$150 from import monsta...
Seems like ur talking a r33 rear???? dont go on 34's cuz of the boot man.
pm me if you need help or pictures....please ignore the first line.. makes me look good.
im on crack... its funnnnn... i like stars and the moon.
I want a r34 rear strut :D
la la la la la la la la la
what have i told you!!! If you want a cusco sticker so badly, i will get you one!!!! You dont have to get the rear strut to get the sticker, i have a spare one for you.
Geez...the things kids will do for an extra 5kw's.... :D
Edited by SunnyCoast
shopping list yewwwwwwww
il leave it up to your car for that :D
makes mine look better.... when i eventually get it :D
anyway Miss Samantha im sure if you look around you will find a rear strut brace suitable for your GTT. like sunnycoast said there shouldnt be any cutting involved :(
why do you say that? they arent very expensive, i rekon they are a good handling mod.
i noticed a huge difference in handling on 34's.. im sure sunny coast will be able to tell u if it made a difference in both 33 and 34 considering he had one in both
Edited by Darkness_Ryda1
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
