http://www.pgasa.com/
professional golfers association of south africa
no, seriously, Pulsar Group of Australia - South Australia
if we had a dollar for everytime that joke.... :P:laugh:
oooooo k.. pulsar something australia australia.. got redundancy?
well i mean they drive pulsars.. so yeah haha enough said :(
ha ha Steve, I'll take your s13 on in my pulsar, at Mallala of course :P
  • Replies 137
Posted Images
if we had a dollar for everytime that joke.... :P:O
ha ha Steve, I'll take your s13 on in my pulsar, at Mallala of course ;)
i just might u know. car is very close to being completed. will be interesting to see how it does on the track.
Anyone else keen to enter their car in this on Saturday?? It's only $40 to enter and find out how much power your car is making :wave:
I will be there and depending on my mood
the car just might get a dyno run
just suck it up and stick it on krishy :wave: i've gone a few kw's up, with the hiflow you might get a few back on me!
i will if i can get my car serviced before then
last year from memory there was no other SAU representative and the only other import skyline was Jack Baker tyres who was a sponsor
Well done for representing SAU last year Steve........there was a bigger SAU representation this year with Destroy, Jenkies, Krishy, Luke ENR34 and me last minute (after alot of arm twisting), lol.
Here are the 2007 & 2008 results:
2008 Results
PGA_Dyno_Day_2007_Results.doc
sorry i couldnt attend, work commitments. 1 kw... baahahahahah awesome stuff. should have got them to run mine first thing in the morning when it was cooler ;) nice work pete!! a big thanks to chad for whatching over my baby! so much appreciated!! luke.. glad you could make it :D
hopefully have the line back on monday then i can take her for a graceful drive down to victor harbor.. suss it all out!!
cheers to all involved!
yeah sorry about that bud, I think we both ran approx 16psi boost but with my ball bearing/cooled turbos I had alot more left in the tank. I told Brett to run them on par with each other in RWD mode......I didn't think they'd be so close though.
Your car has become a bit of a beast now Mark and was running very crisp with no smoke belting out the back, unlike mine that bellowed out black smoke............got to pull some fuel out of it but I'll leave it until the turbo swap happens.
Anyway, congrats on the trophy & prize bud and be careful you don't go losing that license again with all that power on tap now :D .
Dang, spewing i missed this, had to pull out due to cricket and knock issues. I wouldve placed about 4th in RWD too :thumbsup: Well done Pete and Jenks, a couple of cars getting faster and faster, making it harder and more expensive for the rest of us to catch up :D
Dang, spewing i missed this, had to pull out due to cricket and knock issues. I wouldve placed about 4th in RWD too :P Well done Pete and Jenks, a couple of cars getting faster and faster, making it harder and more expensive for the rest of us to catch up :)
ohh it was a freaking awesome day
the dyno room was air conditioned so i dont think that the weather really affected any of those results
hahah damo i made 179rwkw on 7.8psi of boost with a 15sec ramp rate
could have made more if i had ran more boost
and pete your smoke machine sounds insane lol
it was a good turnout and good to see/hear SAU taking care of high power lol
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
