  • Replies 47
Thanks for all the positive feedback guys! Stoked to hear your thoughts.
No its not from Zele-international... whomever they are.
Yeah it is one of the nicest condition imports inside and out that i have ever come across - even underneath is immaculate. Im inclined to believe that the 65,000km are genuine. There is no wear and tear on the seats at al, the brake rotors arent worn any more than youd expect for the km, no indication of anything being pulled off the motor (ie marks on boltheads/screw etc) and the stock radio hasnt even been removed ever. Very honest car.
Cant wait for the next cruise! Hopefully i can KEEP the bloody thing - missus is hounding me to buy a house! I'll know within 6 weeks if im putting it straight on the market for an even $30k or keeping it. Women.
Terrific car. If it were on the market in NZ I would seriously consider selling my house to buy it!
standard turbs... actually i guess the boost comes on early enough going by the guage, its just it doesnt start making serious mumbo till high in the rev range.
Thanks Unique1 (i can remember your last few usernames but not ur actual name haha)
I share your opinion on the bulky autech kit - seemed a bit large but still understated and bland compared to some of the other kits out there. I still dont like the side skirts at all - so if comeone has a set of Nismo or nismo replica sideskirts and wants a swap for genuine autechs - lets do it! But im starting to love the front bar. Looks good. The only other front bar id go for is the one in the thread i posted in the stagea classifieds section.
the name is Brad, i have a set of nismo sideskirts and they look identical to autech ones from what i can see except the little cut out grille things in the nismo ones.
Yeah the nismo ones have the flutes up the front, and if you look closely you can see the autech ones have a wierd spot 2/3 way toward the back where the bottom edge lifts up for some reason. You cn see it a lil in the first picture. Looks gumby. THere are a couple of other differences to such as the top edge on nismos that starts above the flutes angles down to the rear wheel arch, on autechs it is straight parallel with the bottom of the doors, the angled downwards edge on the nismo ones looks nicer. Just personal taste i guess, i like the look of the nismos a lot better.
if u were in perth i could sell u a set, i got a full nismo kit and a set of spare nismo sideskirts as well, i dont want any of it now, im more into the dayz kit and some fat rims like yokota13 has done, looks a treat and the kits arnt fibreglass either so they dont shatter if u hit em.
the motor pic of yours looks very very clean too, i think some nice rims on the car and it will look even better :blink:
Yeah rims are next - im going to put some decent semi slicks on the stock 17s and keep them for track days. For the road the car will get a set of 19 or 20" rims. Hard thing is the 20 - 30 offsets front and rear i think. The engine bay is very tidy on it. no grease, oil, coolant stains, worn bolts, loose bits or anything. all i did was hit the black with some so easy tyre rejuv and wiped it clean. Its immaculate under there.
Smooth car, Bob :/
No!!! Ian!!! dont look at my shit photography!!! haha camera phone dodgyness...
THanks for the feedback im lovin it! i knew i made the right decision...
Shotgun on the Rims if you end up selling them. I have always wanted a set of those. PM me when you are ready :)
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
