hi guys,
i have a new gizzmo shift light & its too bright for the steering column so im asking for ideas of where else it will work - another member suggested the bottom of the a piller which i think i'll try...
any other ideas out there?
Edited by Marko R1
https://www.sau.com.au/forums/topic/225295-best-place-to-mount-shift-light/
yes i did...the green wire goes on the ecu side of the rpm signal & the blue wire goes on the tacho side of the rpm signal.
you need to physically cut this rpm signal wire so that the actual rpm signal runs like this:
ecu side (rpm signal wire) > green wire > shift light > blue wire > tacho side (rpm signal wire)
the book explains this - this is what i used.
im in syd...little bit far from adelaide
feel free to call me if u need further clarification on 0404884876 or email me [email protected] & i'll email you the wiring diagram which is also shown in the manual (except it doesnt point out the rpm signal wire)
  • 1 year later...
hahaha
ull see soon its in production but basically the triple guage cluster in the middle of the r34 console holds 3 guages (no shit) im gonna make like a lil add on, on the right side of it above where the boost guage is
like another pod for the gizzmo shift light.
im still trying to work it out in terms of electrics to be able to change the shift point easily. (i think i can do it with my wolf v500 but we still working on it)
so after i have worked that part out the fibre glassing bit will be piss easy and it will look intergrated into the dash as well so less noticible to the cops. then ill send it off to china and have it made in carbon fibre.
ill keep u posted
  • 3 weeks later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
