Hello all,
very new to this forum, and just bought a GTT two weeks ago, but i thing my suspension is too hard that the parker light cover (the dome shape one)inside the headlight has fallen off, anyone out there has experienced this issue? any idea how i can get it fixed? any help will be much appreciated.
Ryan
https://www.sau.com.au/forums/topic/225298-r34-parker-light-cover/
does the car have aftermarket suspension? Lowered? My r34 came with factory option bilsteins and It handles and rides like a dream.
Regarding the headlight, if you mean the dome bubble thing that distributes the light from the parker, as far as I know you'd either need a whole new headlight or open your existing one up then glue the cover back on, there's a tutorial somewhere on the forum that shows you how to open it up because a lot of guys on here get a chalky build up on the inside of their headlights
good luck,
welcome to the forums
Edited by Yo-Yo
good luck,
Thanks alot for the info, and yeh, my car has TEIN suspension and its quit bumpy sometimes.. anyway, i will try to search the forum for the tutorial.
cheers
Depending on what type it is, majority of coilovers come with varying levels of damping adjustment and let you adjust the damping setting with a dial on the top of the struts
In saying that too a coilover will almost always seem harsher to ride on than a traditional shock and spring, on the upside your car will seem like it's riding on rails if setup is properly done
You might already know all of this already, but I don't know your personal technical knowledge
cheers,
PJ
Yeh, i am still playing around with my suspension setting to make the car goes better, i had the cover clipped back in but after one drive, its out again, this is pissing me off...... will try to glue it in this weekend, hopefully can get it in place, coz i dont wanna put the headlights in the oven.... :P
  • 2 years later...
how did you get inside to clip the cover back on?
Put your headlight into an oven, SAFELY heat it and clip it back on.
If you aren't confident, then DONT do it lol, they are worth too much to be playing around with them.
Take it to a headlight specialist that clean lenses, they'd know how, and maybe get them to clean the lense whilel they are at it lol
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
