What will an R32 GTR with 1017.3rwhp, weighing 3156lbs, with 198lb driver and a full tank of fuel, Castrol Edge 10-60W oil, trust sump extension, RE71 street tires on stock wheels with stock 250,000km gearbox, on a 18.5 degree day with +4m tailwind, run at 12.35pm @WSID on a Saturday, first time to the track? :(
There is plenty of info on the projected and actual times achievable...with good and not so good steerer's. Can we also ban the "how do I make XXX Kw with my RB25/6 GTS-T GT-R R32,3,4" Maybe it's time for an FAQ/Guide on the subject. Just saying :thumbsup:
i 3rd that :D
Interesting, I was expecting to get flamed for the idea lol.
The other idea I had was an approximation of power to times but there's too many variables...so maybe just a where to drag sticky :)
Yeh, ban them all...........bring back the im i a GTR want to be thread.....
There is plenty of info on the projected and actual times achievable...with good and not so good steerer's. Can we also ban the "how do I make XXX Kw with my RB25/6 GTS-T GT-R R32,3,4" Maybe it's time for an FAQ/Guide on the subject. Just saying :)
well found out 2night at wsid my 34 ran 11.6@123mph with 2.0 60ft so certainly got a bit more there . Running on 19inch volks and rubber band tyres makes getting off the line abit of a hit and miss affair .
Dude, beg/borrow/steal 4 x 32 GTR rims and some Mickey radials and there's a very low 11 in that car if not a high ten.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
