Because I know there are a bunch of IT savvy people on SAU, I figured id post my problem im having here hoping someone may have an answer for me. Im just copying and pasting posts ive made on other forums. I know its long, but any help would be appreciated.
Hey guys, need help with trying to get a Graphic Card working that I recently purchased.
Its a HIS x1650 Pro 512mb AGP.
Very similar to this card. However instead of the GT version its listed as Pro. Otherwise identical.
http://www.hisdigital.com/html/product_ov.php?id=345
I bought this to give my old PC a last kick. I've only got AGP so this was one of the better options available.
Installed this card and went to install the drivers off the CD. After driver installation on my Windows XP drive, the graphics came up all distorted and the windows defaulted to 800x600 with 8 bit colour. I uninstalled the software that came with the card and downloaded the latest drivers and catalyst off the ATI site. After installing that, same results and the whole system was unstable. Constantly crashing and after a few restarts, the WINXP HD would no longer boot. Tried booting safe mode to remove software and reverted back to my original GC a Radeon 9550 but still XP refused to boot. Bugger.
Booted on my Vista HD and the graphics appeared distorted. Installed the drivers off the HIS site, vista version and it booted okay. However system was very unstable and the card would keep crashing. It would either be restarted by ATI's VPU Recover software, or it would just lock up. After uninstalling all software from the x1650 and putting the 9550 back in it booted okay.
So I decided to fiddle around with it on a fresh HD to try eliminate any other faults. I disconnected the other two HD's and put in a third HD. Clean install of Win XP Pro SP2. Also disconnected other components to help eliminate any issues. Only left the one HD and optical drive attached, removed sound card, raid card, TV tuner card.
Installed motherboard drivers for AGP and others.
* Installed software off CD and graphics card didnt load (800x600 and 8 bit graphics)
* Another Clean install and tried with only drivers off the HIS website, didnt work.
* Another clean install and drivers from the ATI website, didnt work.
Note: When I say it didnt work, either the graphics card didnt load properly or it was so unstable that even opening my computer or start menu caused it to crash and need a restart. Sometimes getting to the point where windows XP wouldnt reboot.
Did a clean install and didnt bother with motherboard AGP drivers.
* Installed software off CD, graphics card didnt load. Uninstalled the ATI catalyst and card driver. Left the other components in there that the installed put on (MS C++ distribution, .NET 2.0 framework and one other component). Then I reinstalled the drivers and catalyst off the ATI site. It booted and seemed to be working okay. However when trying to do anything slightly graphics intensive, the computer would freeze and need a restart (for testing I installed Frozen Throne which it couldnt even get past the menu without crashing let alone start a game).
So after all of this im planning on returning the card today. I know MSY can be tight asses when it comes to returns and they will probably only exchange it at best for the same thing. However the LED light on the cooler doesnt light up so im going to use that as an excuse to return it within RA/RMA period.
Others things to note is that the card requires a connection to the power supply. It uses a standard FDD connector. I though possibly power could be an issue as I only have a 400w power supply. To test this though I removed all cards and drives, including the network card even and only had the HDD, Optical Drive and graphci card connected. I even disconnected case fans. Still made no difference so I doubt this is the issue. The fans on the graphic card power up and run fine regardless of whether or not everything is connected or removed. I also tried using the floppy connector on my power supply as well as the dongle they package with it which converts your standard IDE power cable to the floppy attachment, no difference.
My machine specs are as follows.
Pentium 4 2.4ghz HT
1gb DDR 400 Kingston RAM
1 x 200gb HDD (Vista drive)
1 x 180gb HDD (Original WinXP)
1 x 160gb HDD (Testing WinXP - note: this was not connected to the raid card while troubleshooting)
2 x Pioneer Optical Drives (DVD & DVD-RW)
Normally uses Gigabyte Radeon 9550 128mb AGP 8x GC
Motherboard is a Gigabyte board, cant recall model number atm (at work)
Any suggestions on what to do or how to fix this problem would be great. I've tried searching the net and there have been multiple others with problems with this card but couldnt find one that listed the same problems as i'm having and how to fix it. Go nuts.
_____________________________
"Went down to MSY after work today and exchanged the GC for a new one of the same model. Also purchased a 550w power supply. The manual recommends 400w minimum so surely this should suffice. And it definetly has 12v 20w rails. No luck thus far, same issues.
Motherboard is a Gigabyte P4 Titan series. Model number is: GA-8S648FX"
"Yeah, pretty much covered the Power Issue I think.
The monitor im using is a CRT. Its a Philips 107E4. Which I believe is a decent CRT monitor. And im running it on minimal settings for what the monitor is capable of."
"Testing now using the LCD attached to my mac normally. Its a Philips 190G. Im running it at very modest settings. 1024x768, 32bit colour and 75hz. This was the same on the CRT, but i figured id keep it safe on the LCD as well while testing.
The CRT monitor and LCD both run fine using the graphic card im updating which is a Radeon 9550 128mb. Im using Warcraft 3 Frozen Throne for testing as its a pretty simple game thats easy to reinstall as im doing clean installs of windows every now and then. On the 9550 its flawless on full settings. On the x1650 it crashes at the menu after the intro movie. Also ive loaded the game on the 9550 and set the video settings to 1024x758 at 32bit.
Still no luck.
Being the second card now, while its possible its less likely the card is actually faulty. Ill keep trying different things and see what I get. Next step I guess is to go through the rigorous test or trying earlier catalyst software. It came with 8.4 on the CD and ive tried that and 8.6 off ATI's site. I've read of some people sing as early as 6.2. It seems a bit extreme, but ill see how it goes."
https://www.sau.com.au/forums/topic/225370-pc-graphic-card-problem/
a wierd conflict on the mobo or something wierd in the bios
check the usual shadow ram crap on the video card
check the agp settings, reset bios to defaults
check for bios updates
Agreed.
Try what paul has suggested.
So it appears after all this it may just be a conflict between the graphics card and my motherboard.
I tested the GC in a spare PC I have and it worked perfectly fine using drivers off the ATI site first try. There are some BIOS updates for my motherboard but they are all in relation to CPU changes, so I doubt they'll work. All I can really try with my existing machine is to use an earlier catalyst version and see if it works.
My other option is to make my spare PC my main one. Most parts are transferable but the main difference will be a drop in the CPU. My current machine is a Pentium 4 2.4ghz HT with 800mhz fsb. The spare is an AMD Athlon 1800xp with a 400mhz fsb.
RAM, HD's, Optical Drives, Sound card, etc can all be moved across. One issue that im slightly worried about is that when this was my brothers PC it often overheated. Whether thats an issue with the Athlon processor or whether thats just got to do with where he kept it (under the desk in a small area) im not 100% sure.
Need to decide if the drop in CPU speed is worth the change in graphic card from a Radeon 9550 128mb to a Radeon x1650 512mb.
I had the exact same problem with the same card. All I did to fix it was delete the driver and the catalyst control centre, then just reinstall the driver but not the CCC. Been working fine ever since.
Have you tried the alternative drivers from Omega's Corner?
http://www.omegadrivers.net/
They're based off ATI drivers but tweaked for performance, its debatable if its faster than ATI or not...
-In the bios check that graphic display option is set to agp and not pci.
-also set the graphic aperture up around 32mb.
-ensure all elements of the old video driver & applications are removed, reboot pc
so it's working in 8/16bit mode with default windows driver then run install of new card/software.
Try even going into device manager, right click on the video display adapter and choose uninstall
reboot and try install with the new card & software.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
