Nice clean work there, mate - looks good. Personally I wouldn't mount both the mid and tweeter in the kickpanel. Maybe do the mid there and find a place for the tweeter where there's still a clear path for the sound to reach the ears of the people in the car. High frequencies are very directional, and you'll lose them altogether if they're down by your feet. I put mine up behind the mounts for the wing mirrors which works fine. Ideally they should be closer to the main driver, but it was easier this way.
I've never seen that door/seat trim in a 32 before? Is that an NA model or something? EDIT: Ah, it's a 4 door by the looks of it?
Edited by HuH
  • 4 weeks later...
Hasn't anyone put speakers in their r32 kickpanels before?
I cut the middle out of my kickpanels and mounted the speakers in mdf rings that were held in place with metal straps.
I listened to them like this and tried different angles by adjusting the straps.
Once I was happy with the sound I made fibreglass backings and stretched fabric over them before coating them in resin and laying fg matting behind them.
After a bit of sanding they are ready to cover in vinyl.
Due to the complicated contours the vinyl will have to be vacuum formed so I've sent them away to be done.
I'll post more pics when they're finished.
Awesome job.. but the problem with having speakers so low and fr away in the footwell is that it bring the "Stage" of the music very low.
I used a single 3 inch tweeter at the base of the A pillar and it really opens the sound up and brings the tage almost head level..
I was hugely surprised.
Just a thought..
Just a thought..
It's much easier to get stage height than it is to achieve a solid centre image in a car.
The main reason for placing speakers in the kickpanels is to get them as far away as possible so that the difference in the distance between the left and the right speaker and the listener is as small as possible.
There can be issues with stage height but careful postioning and angling of the speakers and tuning with an equaliser can help overcome this.
I spent time listening to this setup before building it in fibreglass and the stage is dash top height at low volume but rises above that as the volume increases.
thats brilliant man, great job, very good idea with the metal bar too, i would even suggest doing the same for the passenger, there is nothing worse than having a passenger come in and kick the crap out of your nice new setup, and it looks kinda stylish too.
I agree with the placement of the tweeters that they should be up higher, i think that you can go wrong putting them on the panel opposite the door mirrors, considering its a common place its probably because it works well.
But anyhow nice work, look forward to seeing the tweeters in
I thought about using a bar on the passenger's side but if I put it in the same position as the bar needs to be on the driver's side it wouldn't do much to protect the speakers anyway.
I'm not sure I follow your comments regarding tweeter placement, typo perhaps?
There is no perfect place for speakers in a car so placement will always be a compromise.
The bottom speaker is my tweeter.
I said why I chose this setup in a previous post.
The stage height is quite good, even excellent at higher volume.
Our ears are easily tricked by careful alignment.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
