Wakefield Park Track Day 16/9/03- all welcome (organised by OZ GTI-R Owners Club)
  • Replies 176
Mr R32 M-Spec, pheasant's nest Mobil is the first servo on the motorway after campbelltown, can't miss it.
Looks like I'll catch you guys down there b4 9.
Can't wait to give all those pesky gti-rs a beating :wave:
oopss sorry Mark.
didnt read your post properly!
Yeah, get on the m5 and its teh first servo on the HIghway after cambletown.
Just ring me if you need.
Oh - I just remembered - BigBoganDave will know where it is!!!
ok guys, I'll be leaving in a couple of hours (going to stay overnight so I don't have to get up at 5 AM like you fools :wave: )
If anyone needs to contact me for whatever reason, I can be reached on my mobile: 0405 186 433
I'm looking forward to giving all those pesky skylines a beating :)
Anyway, it's going to be a great day. See you at the track.
Richard
hey GSR 13s, top time!
Once I got rid of my ballast I got down to 1.11.5s, at least I got to zoom all those pesky GTiRs :)
Thanks Richard & Sam for organising everything (except for that bloody wind....) top day out!
I was very happy with the time actually, first track day with the 'R'..
can't wait to go again :)
I only put the Coil overs in on saturday, so they need a bit of tuning to get right. The rear was pretty 'floaty'. Might have to grab some cheater tyres for next day out....
...pretty talkative ballast, probably hurts concentration having a pigeon holding a camera in the car as well:rolleyes:
GSR13S, was scoping out your car, very nice. Imagine how much quicker you can go once you get that high drag rear bumper fixed! :)
Can i ask how you were you timing your laps?
heh, it may be too early to say this, but despite a fair few laps more than normal, this may be the first track day I've ever returned from not needing new tyres or brakes!
And good to meet you there too, Mark, we need to get you over to Eastern Creek as well!
GSR13S, was scoping out your car, very nice. Imagine how much quicker you can go once you get that high drag rear bumper fixed! :(
hehe Thanks, yeh well the damage was caused by a 4WD using my car as a brake at a set of traffic lights :D
Times was obtained with a mate using a stop watch, not precisely accurate but pretty close.
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
