Wakefield Park Track Day 16/9/03- all welcome (organised by OZ GTI-R Owners Club)
  • Replies 176
Mr R32 M-Spec, pheasant's nest Mobil is the first servo on the motorway after campbelltown, can't miss it.
Looks like I'll catch you guys down there b4 9.
Can't wait to give all those pesky gti-rs a beating :wave:
oopss sorry Mark.
didnt read your post properly!
Yeah, get on the m5 and its teh first servo on the HIghway after cambletown.
Just ring me if you need.
Oh - I just remembered - BigBoganDave will know where it is!!!
ok guys, I'll be leaving in a couple of hours (going to stay overnight so I don't have to get up at 5 AM like you fools :wave: )
If anyone needs to contact me for whatever reason, I can be reached on my mobile: 0405 186 433
I'm looking forward to giving all those pesky skylines a beating :)
Anyway, it's going to be a great day. See you at the track.
Richard
hey GSR 13s, top time!
Once I got rid of my ballast I got down to 1.11.5s, at least I got to zoom all those pesky GTiRs :)
Thanks Richard & Sam for organising everything (except for that bloody wind....) top day out!
I was very happy with the time actually, first track day with the 'R'..
can't wait to go again :)
I only put the Coil overs in on saturday, so they need a bit of tuning to get right. The rear was pretty 'floaty'. Might have to grab some cheater tyres for next day out....
...pretty talkative ballast, probably hurts concentration having a pigeon holding a camera in the car as well:rolleyes:
GSR13S, was scoping out your car, very nice. Imagine how much quicker you can go once you get that high drag rear bumper fixed! :)
Can i ask how you were you timing your laps?
heh, it may be too early to say this, but despite a fair few laps more than normal, this may be the first track day I've ever returned from not needing new tyres or brakes!
And good to meet you there too, Mark, we need to get you over to Eastern Creek as well!
GSR13S, was scoping out your car, very nice. Imagine how much quicker you can go once you get that high drag rear bumper fixed! :(
hehe Thanks, yeh well the damage was caused by a 4WD using my car as a brake at a set of traffic lights :D
Times was obtained with a mate using a stop watch, not precisely accurate but pretty close.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
