yes 2 litre is SR20 and 1.8 litre is CA18. the power figures im not too sure prolly around the vicinity of 120 odd KW at the flywheel, prolly 80-90 at the wheels. do it up just the exhaust and filter upgrade, u want sum serious power sum internals, or else forced induction!
there was a write up in a fairly recent hpi magazine of someone who had done adbsolutely everything to his CA18DE, cams and extractors were the most worthwhile. i think he still only made 87 rwkw though. i think 1991 is the changeover year ie where they changed from CA18 to SR20. i researched silvias a fair bit a while back because i was going to get one but i realised a skyline is better :O
That article in HPI, the guy had a later model 180sx with an SR20DE with VVT if i recall correctley.
They didnt make much power from that engine at all, they almost went backwards when they added the first set of extractors (lost a fair bit of mid range)
hey i had a excel with a pod and extractors and exhaust it ran a 16.3 1/4 mile and my mate had a stock SR20 silvia and i ate him by half a car lenght all the time.. i think the excel had about 60kw at the wheels. hope that helps a little.. mabee just to compare huh
Ok I've got that article from HPI in front of me.
Cat back exhaust - gain nothing
Custom 4-2-1 extractors - lost power "massive midrange hole in the power curve"
Custom 4-1 extractors - gained a little "lost a couple of top end kw, restored midrange punch"
ARC intake pipe - gained nothing "aim to change inlet volume to change the resonant frequency of the whole system, and cause either an earlier or later peak that increases power" sound interseting i think.
HKS 256 step 1 camshafts with timing gears and apexi safc -"remarkable gains" "88kw was the final figure, up from the initial 74 kw"
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
