I trust
LeMans Automotive
in Templestowe, Shane does a great job.
He does all Mechanical, electrical and even new tyre fittings / wheel alignments.
Plus I gota family friend at TGS Performance but I take it to his place cuz his workshop is a bit far out.
He does all Mechanical, electrical and some wheel alignment
Shame you don't know the full story, there is always two sides to every story.
- The "rebuilt engine" was purchased off e-bay.
- EAS were only paid to remove, and fit the other engine.
- They came across ALOT of issues with the engine.
- Fixed some, but customer did not have the money for them to strip the head completely and see what was going on.
- Upon pick-up, last night before Xmas closure (myself and a few other customers had already started the Xmas party), the customer was warned his "rebuilt" engine was not running right and should be looked at ASAP.
- He obviously didn't listen, and decided to boot it.
How is a w/shop responsible for another persons fark up?
If EAS was only paid to install a dodgey engine, why should EAS bare the cost of rebuilding the head, when they had nothing to do with the build?
The person was warned (i was there) and he obviously didn't listen.
service my own car.. as i am a mechanic.. i fix my own things.. whateva i cant do i send to CREATD.. cant speak highly enough of them.. Handling, the car goes to Centreline.. Very good setups and workmanship.
I know how alot of mechanics and workshops are.. know the ins and outs.. so the only people i would really trust is the guys at CREATD..
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
