Hi unfortunately Just after finishing my project Not even being able to drive it 500kms before the unthinkable happened and my car was written off got hit in the Rear End by someone who obviously cant drive. The car owes me well over $50000 I have receipts for all the work and parts i have purchased for it most of the parts were bought directly from Japan. All top of the range japanese parts have been put on this car and the engine is still brand new not even 500kms like i said. I'm stripping everything from interior to motor to panels everything must go selling everything cheap and basically every part in brand new or hardly used. And as i said i have receipts for most of it.
Engine Parts include:
Fully bored and crack tested block with Arias Pistons and Rev conrods
The head has been ported and polished.
It has a Garrett GT3540r Turbo with .82 Exhaust housing with a Hi Mount Manifold which inludes
Oil and Water lines with a PSR wastegate plumbed back into custom V band dumpipe in Which JPC did a fantastic job of making it look factory. This Setup alone cost me in excess of $4000 with out labour All parts i have receipts for and done less that 500kms as my motor was still being run in so everything is in mint condition.
I have Denso 550cc Injectors with an Bosch 044 fuel pump and Sard Fuel Regulator.
Genuine Greddy plenum with Ford XF Throttle body including piping.
Os Giken Cam Gears Gates timing belt
Link Ecu with Hand Controller
2 Way Diff
Manual Gearbox with basically a brand new xtreme heavy duty clutch.
Bilstein Height and Damper adjustable coil overs
black Chrome 18 inch Rims with good tread
Everything i Have put alot into this car and has been modified to make big power was looking at making at least 360rwkw was making 330rwkw on my old setup before motor was built and new turbo etc was put on.
These are just the parts i can think about on top of my head there is plenty more.
I also have a Trust Front bar and nice trust sideskirts clear indicators
The interior is A1 and series 2 i need everything gone.
Going to take motor out this weekend and gearbox etc.
Will post up prices in the next couple of days if anyone needs any parts just let me know and i will take it off for you. I have lost an absolute fortune on this car and whats my loss is your gain just need it all gone makes me to depressed looking at it knowing how much i have put into it.
cheers
Edited by wildr33gtst
https://www.sau.com.au/forums/topic/225450-wrecking-fully-worked-r33-gtst/
  • Replies 49
will put up some prices when i go home im located in bentleigh. Will be home in an couple of hours 2 reply 2 everyones messages and posts. Cheers
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
